Need a stock 302 bin and mask
Old Jan 10, 2010 | 08:44 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
I dont have the ability to get the stock bin off a 302 ECM. What I need is the stock 302 bin and code mask that an 86 2.8 V6 Firebird would have come stock with. I am sure I could dig them up if i knew what to look for.
Old Jan 11, 2010 | 02:56 PM
Ronny's Avatar
Re: Need a stock 302 bin and mask
check craig moates website under downloads.
Old Jan 11, 2010 | 09:31 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
That was one of the places I checked but could not figure out what code mask is used.
Old Jan 12, 2010 | 07:46 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The maskid is $3A for the '7302 in 3rd gens.
You can also use WinALDL with the '7302 ECM as it is a 160 baud data stream.
RBob.
Old Jan 12, 2010 | 06:08 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
thanks alot RBob!!!
Old Jan 12, 2010 | 08:40 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
Ok found the .xdf. One problem though. All the temperatures are in degrees Celsius. Shouldnt they be in Farenheit? I know you can edit XDF's in Tunerpro but I notice when i do, the temps in the graph do not change. Theres a big difference between 60 degrees Celsius and 60 degrees Farenheit. Am I missing something?
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
Reborn756
Sep 4, 2015 03:42 AM
ezobens
Aug 19, 2015 10:29 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
