WB readings with TP/RT
Old Jan 14, 2010 | 02:46 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Hi Folks,
I am using TP/rt to data log my car , the info is great but i am tired of using the NB and want to start using a WB to tune. Is there a "way " to include WB readings with the data stream that TP/RT uses? I have the "bung" in the exh. but i am unsure what way to go, i was looking at the innovate LM-2 . Or can the older LC-1 stand alone WB be made to work with TP/RT?? Thanks GTA.
Update, ok after some searching i know this can be done, does any one have instructions for the wireing and the changes needed in TP/RT to see the info? I've tried the search, and only found bit's and pieces of info ...Thanks again.
Old Jan 15, 2010 | 11:26 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: WB readings with TP/RT
http://www.moates.net/fileman/index....ied%20Binaries
Grap the S_AUJP_V4 1026.zip file from Moates site under Custom Binaries.
Read the two PDF files included. Especially the one on U6 inputs.
They explain how its done in S_AUJP V4.
Any WB product can be used, its just a matter of matching the output of the unit to the scale factors in the software (logger) to make the values read in AFR.
See this post if you have trouble gaining access to the file.
https://www.thirdgen.org/forums/diy-...ates-site.html
Old Jan 15, 2010 | 11:41 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Thanks i will be back with more questions shortly.
Old Jan 15, 2010 | 04:17 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
JP i think i need a PM with ya....i have downloaded the proper stuff from moates, BUT I am just a bit lost.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
