Does anyone know where I can get the UV light erasable Eproms?
Old Jan 31, 2010 | 11:06 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
OK, I am a dynosaur here, but my old stuff still works for me. However, I have damaged 2 of my 4 original Eprom chips and had given one away to help another 3rd genner with the MAF code 33 error. I have checked with Moates about a month ago (or two), he does not have any. These UV erasable Eproms are the 27C128 chips.
Old Jan 31, 2010 | 11:18 AM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
Re: Does anyone know where I can get the UV light erasable Eproms?
check with MCUMall.com, last i checked they had some
Old Jan 31, 2010 | 11:20 AM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I *think* the electronics store in the next town has some on the shelf. I'll try to remember to call them tomorrow for you.
Old Jan 31, 2010 | 11:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Note in the '7165 the '256 EPROM can also be used. Just burn the upper half when programming, or double stack. For those in the -40 to 80 *C range try Mouser (www.mouser.com). Drop "M27C256B-12F6" into the search box.
RBob.
Old Jan 31, 2010 | 02:24 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
http://cgi.ebay.com/Eprom-eraser-Ult...item3ca49ed817
I bought one of these, lined up light source with hole in eprom, cut me a hole in the drawer that matches side profile of memcal, where I could slide memcal in and center hole in memcal eprom lined up and it works great.
I can send pic if you can't see what I'm describing.
I've got one of these also, lay memcal over light upside down and erase.
http://www.best-electronics-ca.com/eproms.htm
Old Jan 31, 2010 | 05:29 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
RBob, looks like you have come thru for me again, thanks. I will call them tomorrow.
Duts87ss, please check into that source.
scuzz, I am looking into the Eproms only. I have had a Dataeraser II for about 12 to 14 years. I am surprised that they are still being sold.
Old Jan 31, 2010 | 05:36 PM
ULTM8Z's Avatar
I have four of them that I'm not using anymore. Finally got into the 21st century and bought the electrical eraseably ones.
e-mail me if you're interested. ultm8z@yahoo.com
Old Feb 1, 2010 | 12:01 PM
Ronny's Avatar
Jameco is another supplier
Old Feb 1, 2010 | 05:21 PM
Duts87ss's Avatar
doc, do you know what "ns" rating you need? Looks like they will probably have some though.
Old Feb 1, 2010 | 05:57 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
ULTM8Z will be coming to my resue here. Thank you for everybodies help.
Old Feb 1, 2010 | 07:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
On a P4 at least a 250 ns chip is required. That and faster will work.
On a C3 at least a 500 ns (450 ns is a standard rating) chip is required. That and faster will work.
RBob.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
