Quick Question About VE1 + VE2
Old Feb 14, 2010 | 01:46 PM
nick9004's Avatar
Car: 1981 GMC Jimmy
Engine: 350 TBI
Transmission: TH350 soon to be 700r4
Hey guys, I just want to be sure about this before I go and raise my BPW and have to retune all of my VE values.
I realize VE2 is added to VE1. In VE1 I know you can enter a value greater than 100 but it will only be counted as 100. This would indicate you need to either change injectors or increase BPW.
Question is, If you have lets say 66.00 @ 2400RPM and 80KPA, then in VE2 at 2400RPM you have 39.00. Would this be the same as having 105 in VE1 and 0 in VE2 indicating your VE tables are maxed?
I hope that makes sense. Thanks!
Old Feb 15, 2010 | 06:23 PM
skwayb's Avatar
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
Re: Quick Question About VE1 + VE2
That is correct VE1 + VE2 when added together cannot be larger than 100.
Old Feb 16, 2010 | 02:39 PM
Ronny's Avatar
I hope this is right! It has been a while since I used adder table(7747). I recall you can zero out all in table #2 cept the lowest rpm value zeroing cells through 3200 keeping those RPMs above 3200 to tune with in table #2. That make the calcs easier and quicker. I forget why lowest RPM in table 2 is not to be touched. Can someone confirm?
Old Feb 16, 2010 | 03:51 PM
nick9004's Avatar
Car: 1981 GMC Jimmy
Engine: 350 TBI
Hi guys, thanks for confirming. Looks like I may have to find some larger injectors on the next Pick n Pull run. I beleive your right about the 400 RPM row Ronny, I have also read that recently on here.
Thanks Again!
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
