Tuner Pro RT shutsdown and bad checksum update
Old Feb 18, 2010 | 02:26 PM
patcon's Avatar
Back in the fall of 09, I had started doing some BIN editing, because my mail order stuff wasn't working. I am working on a BJYL file for a 95 suburban, I have a chip header and downloaded the BIN through a Burn 1 unit. Then the laptop I was using crashed and I lost everyhting and my copies of Datamaster, Tuner Pro, etc.. Datamaster was not available until last week due to a windows 7 upgrade. I downloaded Tunerpro RT v4.14.0381.00 down on to my desk top running Windows 7 and my laptop running Windows XP. I tried to look at a BIN on the Windows 7 machine. I selected a definition (OD_V1_02), then a BIN(the original BJYL) but some where in between there and trying to look at a constant; it said this app has an error and must close. I figured it was a Windows 7 problem so I tried the XP machine, but it did it also. I tried to open up something again and on the second try it worked on the laptop with XP. I edited my BIN file and went to SAVE AS another name. When I did it said it could not update the check sum. I have not had that error in the past. I made the same edits previously before the other laptop crashed. How do I deal with these issues. I posted this on the Tuner Pro community site and have not gotten a response. Can I use a BIN that didn't update the checksum? How do I make it update correctly?
Thanks, Charles
Old Feb 18, 2010 | 03:01 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Tuner Pro RT shutsdown and bad checksum update
No one has replied because I would bet no one has experianced that. TP is designed to automatically update the checksum upon saving.
Have you tried un-installing and re-installing TP RT?
Have you tried TP RT V5?
Old Feb 18, 2010 | 03:52 PM
patcon's Avatar
Hey Six shooter, long time no talk. How is your Z running? I am welding in patch panels in one on the rotisserie. I have some more info on my checksum issue. I downloaded the stock BIN from the EPROM about a week ago. I started looking at it closer today and a lot of values are 0 so I pulled up a spark table and it is like -81.5 across the board. So I assumed I did something wrong in the downloading. I used another machine, flash n burn and a burn 1 to read the chip agian, while reading the directions from Moates. The BIN I read off the chip today is the same as the one I downloaded the other day. So I assume that means my stock EPROM is toast? Does soliciting a stock BJYL constitute PROM begging? I haven't found one on any of the sites I have searched (95 suburban, 2 wd, 4l60e, 350 ci). I know the fuel tables will have to be reworked but the spark tables should be a good starting point and all the transmission stuff should work for a while.
Thanks, Charles
Old Feb 19, 2010 | 11:19 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Confirm the bin file is not read only or in a folder you do not have permissions to modify files. That has bit me before.
Old Feb 24, 2010 | 12:02 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
If trouble persists, send me the bin file and XDF file you're using and I'll set you straight.
Old Feb 24, 2010 | 08:31 AM
patcon's Avatar
Thanks Mark,
I hope to try to tune some this weekend
Charles
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
Stryker412
Sep 7, 2015 09:11 AM
Amillionoh7
Sep 5, 2015 11:44 PM
andy74
Sep 3, 2015 08:41 AM
