Code59 Tunerpro5 Files - Released 2/19/2010
Old Feb 20, 2010 | 12:59 AM
skwayb's Avatar
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
I finally got around to getting the files into a release form. These are still a work in progress but you should be able to connect and play with the new dashboards, history, monitors, etc.
Also I put a MPG calc in the ADX file. (Thanks JP86SS for the formula for MPG and some good dashboard examples) For you to use it, you will need to change the Injector Constant in the ADX. It is a rough estimate but it works fairly well.
If you come up with something you would like to see as a dashboard, history, monitors, etc, post them. We would like to add what you guys want to see and would use into the ADX file.
You can get the files here. (you need to be registered on Code59 to download the files)
http://www.code59.org/index.php?opti...tid=13&id=7138
Old Feb 20, 2010 | 07:58 AM
AC's Avatar
AC
Car: Used to drive a camaro
Re: Code59 Tunerpro5 Files - Released 2/19/2010
This is great, just in time for driving season to start too!! Great work as always. I'll make sure any feedback is left on Code59 as well once I start working with it.
Old Feb 26, 2010 | 05:54 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Great, cant wait until the snow is gone and the car is put together again
Old Mar 3, 2010 | 12:21 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Good stuff. Love the dashboards. In the item lists, under Flags, you've got some missing dependencies, most likely due to you having deleted the related bitmask items in the definition.
Also, I see economy in the definition and dashboards, but not in the item list.
InfernalVortex
Apr 20, 2021 11:31 AM
jrdturbo
Mar 31, 2016 02:58 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
