Bad PROM?
Old Mar 10, 2010 | 07:46 PM
jonnybcamaro's Avatar
Car: 02 T/A
Transmission: Built 4L60E
Axle/Gears: 3.42 Posi
Bad PROM?
I am about 99% sure that my prom has gone bad, but I am double checking so I don't throw money at the wrong thing.
Car runs perfect... sometimes... other times it runs rich, has extreme loss of power, idles high or low, engine sometimes cuts in and out like it isn't getting enough fuel or too much. When this happens the SES light just blinks on and off. Only once was I ever able to get it to actually throw a code, and it was 51. (when the car would die after running like crap or after I would shut it off and try to run the codes it would only show 12) 51 is a bad PROM, amd I am just trying to double check with other people that would know a little bit more about this than me. Thank you guys very much!
Jonny.
Old Mar 10, 2010 | 08:13 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: Bad PROM?
Mine did that, the problem
was that the prom wasn't pushed
down all the way. I had the same code 51
Old Mar 11, 2010 | 08:53 AM
Car: 02 T/A
Re: Bad PROM?
I have it pushed in all the way, I pulled it out to check and see if any of the pins were bent, and I made sure it seated fully and properly when I put it back.
Old Mar 11, 2010 | 01:35 PM
Ronny's Avatar
Re: Bad PROM?
A bad prom or prom connection I find is a rapid blink of CE light. Intermittant is hard to diagnose.
Old Mar 12, 2010 | 09:43 AM
Car: 02 T/A
Re: Bad PROM?
Well, I am just going to replace the PROM and hope to god that fixes it.
Old Mar 16, 2010 | 12:21 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Bad PROM?
I got the same problem. I got a Hypertch chip in mine. Let me know what happens with your new PROM.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
tyeo098
Nov 30, 2015 06:27 PM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
