Map Sensor Hose Length?
Old Mar 16, 2010 | 06:27 AM
dave w's Avatar
I used the search feature to find an older posts about Map Sensors: https://www.thirdgen.org/forums/diy-...p-sensors.html
My question is: When a Map Sensor is correctly placed (hose nipple pointing down / positioned slightly higher than the intake plenum) onto the firewall, what is the maximum length the hose can be?
I'm retro fitting a TPI system into a Classic Chevy. I'm converting a MAS system to a MAP system using a 7727 ECM. The MAS upper plenum does not have a mounting position for the MAP sensor.
Thanks,
dave w
Attached Thumbnails Map Sensor Hose Length?-0314001611.jpg   Map Sensor Hose Length?-dscn2806.jpg
Old Mar 16, 2010 | 08:28 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Map Sensor Hose Length?
All info I have found, and seen myself indicates that until the hose is very long, longer than would ever be used in a car, that there will be no appreciable difference than if the MAP sensor was mounted to the intake directly.
The biggest thing to watch out for is to use a hose that will not collapse from the vacuum.
Old Mar 16, 2010 | 02:06 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
you can use a long hose/tube as six_shooter says. The best method would be to use hard line, whether plastic or metal, and make the interconnects rubber, so the overall length of soft collapsible material is short.
Old Mar 16, 2010 | 02:58 PM
Ronny's Avatar
Braided stainless with AN fittings could add a lot of bling!
Old Mar 17, 2010 | 12:07 AM
dave w's Avatar
Thanks for the information. This information helps!
dave w
gta892000
Aug 11, 2019 11:16 AM
racereese
Oct 10, 2015 09:39 PM
customblackbird
Oct 1, 2015 04:30 PM
Scorched1984
Sep 15, 2015 03:42 PM
FormulasOnly
Sep 10, 2015 09:07 PM
