starting point
Old Apr 1, 2010 | 05:28 AM
CRASHANDBURN_01's Avatar
Car: 87 ls1 camaro 510 rwhp
Engine: 2002 ls1 cam carb and juice
Axle/Gears: 4.10
starting point
ok so i have a 89 gta trans am motor with a zero deck block, flat top pistons, lunati voodo cam, 28 lb ls1 injectors, long tube headers, cat eliminated true dual exhaust, and a custom cold air intake with open element filter. reused factory computer (165) and modded factory harness all transplanted into a 78 chevy c10 pickup. i started by setting the injector size, and turning up the target idle across the ect board to 1100 just to get it to idle (otherwise it wont) my question is my blm is at 160+ and i was wondering about what percentage to skew the maf table vs rpm to get closer to the 128 blm, 5%, 10%, 20%, more? just trying to get the thing back down and idle so i can drive it and go from there
Old Apr 1, 2010 | 04:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: starting point
Adjust the injector flow rate until the BLM values are centered as well as possible on 128.
If the MAF is still stock then work a little on the injector compensation tables. Then move on to the MAF tables for final tweaking.
If the MAF is de-screened, then adjust the MAF tables after the injector flow rate is set to the best value. Then move on to the inejctor compensation tables.
Rbob.
Old Apr 1, 2010 | 07:42 PM
Axle/Gears: 4.10
Re: starting point
what is the pulse width table listed under in tuner pro rt with the 6e bin? maybe i'm just blind or dont understand the lingo. also is there a class or tutorial specifically on the tuner pro software for tuning gm maf computers. most of the lit out there talks about the 730 computers and tuning speed density systems. having a hard time finding 6e specific tutorials on this site or any other for that matter. are they just that uncommon or is it so simple that there isnt much info for noobs like me. it would be nice to find a post specifically on 1.2.3.... steps for tuning the 6e bins just for beginners like me. i can tune anything with a carb on it like my ls1 but i need more knowledge before i dive in head over heels with ecm tuning.
Old Apr 1, 2010 | 08:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: starting point
$6E doesn't have a PW table such that $32/$32A has. So I'm not sure of what is being referenced in the XDF.
There is a lot of information on MAF tuning in the Tuning Guide Book sticky. Chapter 5 for the '7165. Check the MAF Miscellanea link for an over view. Also check the other links.
If you understand carb & distributor curve tuning then you understand EFI tuning. There are only two differences:
1) the lingo
2) mechanical changes vs electronic (calibration) changes
Although one could say that there is a third difference. Which is that an EFI system has a higher level of versatility then mechanical systems.
RBob.
Old Apr 2, 2010 | 06:03 AM
Axle/Gears: 4.10
Re: starting point
thanks rbob much appreciated. read the articl and have a much better understanding now. i just like to gather as much info before doing something as i can as not to f it up
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
onebadazzsrt
Aug 15, 2015 07:00 AM
