.xdf
Old Apr 8, 2010 | 10:35 AM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
.xdf
trying to figure out how to download the $6e mask.. all i can do on the site is open the file and view it or download it as a .txt file.. what am i doing wrong?
when i open it i go to file and select save as.. there is no .xdf selection...
Old Apr 8, 2010 | 11:02 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: .xdf
if you choose to save it as "all file types" or something similar, just add .XDF to the end of the file name and it should save correctly.
Old Apr 8, 2010 | 11:07 AM
Nater36's Avatar
Re: .xdf
ok, cool that worked.. however, now it says mismatched ads and xdf file?
Old Apr 8, 2010 | 11:10 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: .xdf
ok, that's caused by whoever making it linking the XDF to a specific ADS. to fix that, click XDF, View/Edit XDF header, go to the ALDL association tab and then point it to the correct ADS for that mask.
Old Apr 8, 2010 | 11:21 AM
Nater36's Avatar
Re: .xdf
ok got it thank you
ZZ42Fast
Aug 30, 2015 02:39 PM
def1
Dec 22, 2014 06:04 PM
89newfun
Feb 13, 2013 10:12 AM
Highpockets
Nov 5, 2010 11:23 PM
System1
Mar 2, 2009 10:58 AM
