Garbled data,incorect .xdf ???
Old Nov 5, 2010 | 08:49 PM
Highpockets's Avatar
So I have a 92 5.7 TPI car in the shop just finished a new 383 and need to make some adj. Car had been previously "tuned" and has a non stock chip in it.I attached the Memcal to my burner and was able to read the .bin on the chip but when I attempt to open it to modify,the tables are all whacked ! I have tried using the 8DF as well as 8D super.ecu files to read/open the file and while it does show tables they are NOT right. For instance,main spark,35kpa/2000rpm may say .0123 then next cell says 77.32 then 24 then 63 and so on.I am using the latest TP V5 software on my laptop and tried both a burn1 and APU1 emulator/burner with the same results. I suspect I have the incorrect .xdf file any help/direction would be greatly appreciated. This setup is a six speed,speed density NA 383 with a 7730 computer.
SORRY ! .xdf, NOT adf,I am VERY tired and just noticed this !
Old Nov 5, 2010 | 11:23 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Re: Garbled data,incorect .xdf ???
What size BIN file did you get from the chip? It should be 32768 bytes. That's the $8D, so you're on the right track.
It sounds like you might not have gotten a good read.
Try reading the 'stock/modified' chip as a 27SF512, from chip address 008000-00FFFF, and set your buffer addressing from 000000-007FFF.
Save the resultant file, and you should be better off. Things should look 'sane', such as the fuel injector size and timing tables for example.
Hope this helps,
Craig
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
BWilcox
Sep 20, 2015 12:19 PM
