VE vs. RPM vs. MAP question
Car: 1992 LT1 Corvette
Engine: 396ci
Transmission: ZF 6 speed
Axle/Gears: 4.10
Why is it that I see different 2000 rpm MAP values in the following tables?? One is in the normal VE vs. RPM vs. MAP table and the other in VE vs. RPM vs. MAP (EXT) table.
I always see to it that both have the same values, but when I look at other bin files they always differ.
How is my ECM to know which 2000 RPM table to use??
Car: check
Engine: check
Transmission: check
Re: VE vs. RPM vs. MAP question
Typically, as long as the RPM is at or below 2,000 RPM the lower speed table is used. Once the RPM is over 2,000 RPM then the higher speed table is used.
RBob.
RBob: When doing a VELearn with EBL is the lower RPM table changed while the upper not changed when learn is on? I too noticed they are differrent so I need to change the upper to match lower.
Car: check
Engine: check
Transmission: check
My Learn this morning shows exactly that !
I think I misspoke on that. It was in fact the SA tables at 4800 that did not match in my .bin.
