Help wiring in LC-1 to 730 ecm
Old May 3, 2010 | 09:46 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Hi,
I am trying to wire in my LC-1 into my 7730 ecm. I have located the Unused
"A3" pin that i will use for the input, my question is is it really this easy? I am currently using TP/RT V5 it already has the WB set up in there. Has anyone else done this that would be willing to help a rookie walk through it ? thanks GTA
Old May 3, 2010 | 11:46 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Help wiring in LC-1 to 730 ecm
Pretty much that easy if you are using the S_AUJP V4 (1026 version or later).
  • Physically Connect Output wire to A3 or F14
  • Set bit in bin file if using "A3" pin, Clear bit for "F14" Pin.
Location 99B (WB OPT 2, bit 7, Input "A3", Else "F14")
  • Set bit in bin to use the "Raw" output from the WB
Location 99B (WB OPT 2, bit 0, RAW A/D Output)
Select only 1 option for a WB setup.
This "RAW" one is for full 0-5 volt/0-255 count output to the datastream.
If two WBs are selected, the first one wins and you may not get the reading right because it would be scaled for a different WB output.
  • Confirm your scale within the LC-1 is outputting the full 0-5 volt range that equals 7.35 to 22.29 AFR
To Add the item to your ADX logging definition if it does not already exist:
  • Open ADX editor
Go to "Values" in the listing and click where you want to insert a new item
  • Click "Add New Item"
Name it to something you want like "WB Full Range"
Give it a Unique ID value (anything works here)
Type description as desired "LC-1 with full scale output"
Units override = AFR
Packet offset = 0x24 | 36
Source Data Size = 8 bit
Range Low = 7.35
Range high = 22.299
alarms (if you want)
Alarm Low = 12.0, Enabled
Alarm high = 15.0, Enabled
  • Click conversion tab and click "Set"
Enter this: X * 0.058980 + 7.350000
Argument type = Native
Output Format = Floating Point
Output Digits = 2 (If you only want 1 decimal then make this 1)
  • Save
Run your car!
Old May 3, 2010 | 10:12 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
WOW
Thanks JP!! That helps a million!!! Please check your PM as i have some small wire routing issues that i would like to discuss with you....thanks again GTA.
Old May 4, 2010 | 06:20 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
JP,
One more question, what do i do with the " stereo" connections? must i use the terminator plug that comes with the LC-1 or do i just disregard both the In and out stereo plugs? As per instructions which wire do i connect to the unused A3 port "yellow" analog 1 or "brown" analog 2? thanks GTA
Old May 4, 2010 | 10:14 PM
JP86SS's Avatar
The default settings in the LC-1 should be the brown wire scaled to be the WB, yellow wire scaled for the NB.
Run the brown wire.
Terminator plug must be installed to terminate the network from the LC-1 IIRC.
Old May 6, 2010 | 08:28 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
JP, hi
I also forgot to ask, "If" i need to extend the stock wires that came on the LC-1
can it be done without affecting the accuracy of the unit? I am not sure if i can reach the ECM without extending them as i found and used a "Grommet" that is located near the steering column. Thanks GTA
Old May 6, 2010 | 11:32 AM
JP86SS's Avatar
The "loose" power and signal wires can all be extended without worry.
Solder and shrink wrap them good so you don't have problems later.
The Sensor connector and wires I would not attempt to do anything with.
stalkier
Dec 6, 2015 11:25 PM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 19, 2015 12:07 PM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
