OBD 1 scanning software.
Old Jun 4, 2010 | 04:05 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
i would like to get an ALDL to USB cable to plug into my laptop. I would like to get some good free software to use.
Does anyone have any links to this software. thank you
Old Jun 4, 2010 | 06:46 PM
jim_in_dorris's Avatar
Re: OBD 1 scanning software.
tunerpro.com or google winaldl
Old Jun 4, 2010 | 10:54 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
tunerpro.net....
tunerpro.com is something else entirely...
Old Jun 4, 2010 | 11:24 PM
you are correct as usual, I have this mental block about dot net sometimes.
Old Jun 6, 2010 | 05:29 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
I downloaded tuner pro and it seem like it does a little more than just read codes on OBD 1 cars. I was looking for something a little less complex. Im not really into the custom chip tuning.
Old Jun 6, 2010 | 05:36 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
WINALDL
google
Old Jun 6, 2010 | 07:39 AM
dan0617's Avatar
www.moates.net for the cable and for the chips and burner and such when you decide to start your own tuning.
www.tunerpro.net for the software. It works great for datalogging, then will work great when you decide to start your own tuning.
Old Jun 6, 2010 | 10:45 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Originally Posted by Gumby
WINALDL
google
isn't WinALDL 160baud only? that won't work for a 90...
"I was looking for something a little less complex. Im not really into the custom chip tuning. "
it's only as complex as you want it to be, you can easily ignore most of the stuff if you're just looking to scan for error codes.
Old Jun 13, 2010 | 08:57 PM
robertf's Avatar
Car: Land Rovers
Engine: 3950cc
Transmission: some autos, some manuals
I've got some written in vb.net because winaldl has been really consistant at blue screening windows 7. haven't done any graphics yet mainly because I don't know how. Anyone want to take it over? It also has the neat feature of reading the .bin from $8D through the ALDL.
Old Feb 17, 2011 | 09:18 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
so will Win ALDL work or not being a 160baud? I like it because it has a dash and is easy to navigate.
Old Feb 17, 2011 | 11:11 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
What is it you're looking to do?
If you simply want to access stored codes a paper clip will help you there. If you want to see more detailed data, then tunerpro would likely be what you will want. V5 has customizable dashboards as well.
Old Feb 18, 2011 | 10:32 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
I am looking to be able to plug it in and see some more detailed info. Where can i get the cable to use? the right one? can some one send me a link
Old Feb 19, 2011 | 03:02 AM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
Tunerpro v5 for your software.
ALDL cable either from moates.net or aldlcables.com.
Be sure to get a USB cable, not a serial port cable.
Old Feb 19, 2011 | 12:54 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Is TunerPro V5 free?, and where do i get it from, can someone send me a link
Old Feb 19, 2011 | 04:03 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
http://www.tunerpro.net/downloadApp.htm
you'll need the RT version.
you'll have the full features of the software, however, without registering it, there is a 10 second nag screen every time you launch the program.
Old Feb 19, 2011 | 05:43 PM
90L98$8d's Avatar
You will need to get an ALDL to USB converter also. The cable will connect to your computer through the internet port but tunerpro wont be able to connect unless you purchase an ALDL to USB converter; The ALDL cable will plug into converter and a USB cable will plug into the converter. Its all on the Moates Web site.
Old Feb 19, 2011 | 07:07 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Re...
i will sell you my laptop with Diacom and cable included for cheap, it will do all you want it to and it is very easy / simple to use please PM me for details...GTA
Old Feb 20, 2011 | 09:26 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
why cant i just get one of the aldl cables with usb on the other end instead of using the convertor
Old Feb 20, 2011 | 09:44 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
90L98$8d was referring to the moates cable, which is a two piece unit, one side has the ALDL interface and ends with a RJ45 connector, the other is a converter to make the GM 8192 baud signal into a USB signal by way of a serial-USB converter.
that's basically a moates specific arrangement though, i believe it's done that way due to being able to interchange the 12 and 16 pin ALDL connectors easier.
Old Feb 22, 2011 | 09:50 AM
Ronny's Avatar
Look at Tunercat as well. My impression day one of tuning it was the easiest to use to modify my .bin. It lets you see the basics and then as you progress you can ask for other features at no xtra cost. I used winALDL to datalog. winALDL is a simple and user friendly as you can get.
I bought my cable from customefis $40
junior419
Apr 7, 2025 11:35 AM
1992Z28!
Nov 19, 2015 07:33 AM
RGB2015
Sep 20, 2015 09:26 PM
92firebirdguy
Sep 10, 2015 10:33 PM
whtltng89
Sep 8, 2015 07:06 PM
