g1 vs gp1 adapter
Old Jun 16, 2010 | 08:27 PM
88formula305tpi's Avatar
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Transmission: 5 speed
Axle/Gears: 3.45
g1 vs gp1 adapter
I dont know if I need a G1 or GP1 adapter for a 165 ecm. Is a zif socket necessary or will a G1 hold the chip just as well?
What I am asking is what is the point of a gp1 with a zif, is it just a more secure way of holding the chip?
Old Jul 13, 2010 | 12:23 AM
Grizzlee's Avatar
Car: 89 IROC t-tops
Engine: 5.7 (350 tpi)
Transmission: Auto (700R4)
Axle/Gears: 9 bolt disc with 3.73's
Re: g1 vs gp1 adapter
The adapter with the zif socket lets you swap the chips out easier (using the little lever)... I am just starting to play with burning chips and I have changed the chip several times. The adapter with the zif socket will not allow you to put the cover back on the ecm.
However, once you are finished tuning you can carefully pry the zif socket off, insert the chip and ride into the sunset..
Now if I could only figure out what all the numbers mean??
Old Jul 13, 2010 | 12:42 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
this is true for 7165 and i believe 7730 type ECMs.... the 7727 and other weatherproofed ones however, there is a LOT more room and allows the lid to be closed if you use a ZIF.
InfernalVortex
Apr 20, 2021 11:31 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
romcjr
Sep 17, 2015 05:18 PM
