305 memcal for 355 TPI
Car: 89 Trans Am
Engine: Stealth Rammed 355
Axle/Gears: 10 bolt 3.23
Hi guys, I am putting a 355 TPI in a 305 TPI car, i know my computer is the same for both motors, and i am going to buy the C.A.T.S. OBD1 tuning kit so i can burn my own chips, but my question is can attach my burned chips to the 305 memcal and make it work for the 355? any and all help is appreciated
Car: check
Engine: check
Transmission: check
Re: 305 memcal for 355 TPI
Yes, you can do that. Can either remove the stock PROM and socket the MEMCAL. Or purchase a G1 adapter from Moates. The chosen method depends upon time, funds, and soldering skill.
RBob.
RBob.
Car: 89 Trans Am
I am going to be using the G1 adapter, i just didnt know if having the 305 prom on the memcal with the adapter and new chip installed would cause any problems, but now i know Thanks
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
