-93 LT1 Ecm 16159278 What xdf and bin?
Car: Trans am GTA 1990
Engine: 383
Transmission: TH700R4
Axle/Gears: stock
The chip in the ECM says Delco BDLC 7060 and the ECM nr is 16159278 the engine is a LT1 -93 I have looked all around after an BDLC bin but I cant find one. What Bin can I use instead of BDLC? and what xdf file shall I use?
Car: 1985 IROC-Z28
Engine: LB9
Re: -93 LT1 Ecm 16159278 What xdf and bin?
not sure what the differences are, but ASKW, ASKU, BDLF are all F-body, LT1 6 speed BINs like the BDLC. IIRC, DA2 is meant for 92-93 LT1 vettes, while DA3 is for 93 LT1 F-cars...
or maybe it's DA2 for 92 and DA3 for 93? i really wouldn't know, but it seems like either way, DA3 would be you.
Engine: 383
Axle/Gears: stock
Thanks Saar, I found BDLF and DA3 I will test them and see if it works I report back.
88SS6SPEED
Nov 11, 2015 07:05 AM
