BLM Cells 16 17 18 only in CLOSED LOOP?
Old Aug 10, 2010 | 09:23 PM
chevyspence's Avatar
Car: 84 z28 CMC1 spec
Engine: L69
Transmission: BW T5
Axle/Gears: 3.45 9bolt
Hello thirdgen tuning community,
It seems like there is a lot of knowledge here so maybe someone will be able to recognize my problem.
I am running a 93 LT1/T56 and 16159278 ECM. I use TunerPro RT v4.14 to datalog and burn chips via the Moates PROM. Since I initially tuned it a few years ago it has been running great but it has never strayed outside of BLM cell numbers 16, 17, or 18 (for idle, DFCO, and open loop respectively). I was still able to dial in the VE tables to keep the BLMs in line.
BLM Cell RPM Boundaries: Hi=2600, Mid=1800, Lo=1200
BLM Cell MAP Boundaries: Hi=80, Mid=60, Lo=40
(even though they're very close, I also tried the stock values here)
So my question is: when the ECM is indicating a closed loop condition (with O2 sensors active, "learn mode" enabled, and BLMs updating) what could be keeping me from entering BLM cells 0 thru 15?
It seems like a long-shot, but I am beginning to suspect there is a flag or switch that needs to be set for one of the seemingly unrelated sensors that I am no longer using (egr, purge, etc...) to somehow enable the closed loop cells.
I have attached a compressed folder containing my current XDF ($DA3.xdf), BIN (Current_Tune.bin), ADS (My_LT1_Datastream_D.ads), a short datalog ADL (Current_Tune.adl) and some reference code text files.
The XDF, and ADS can obviously be viewed in Notepad or Wordpad but the ADL and BIN need to open with TunerPro or similar. I can also produce a TTS Datamaster log if it would help.
I feel pretty comfortable with the hardware, software, and theories but I am missing something huge here!
File Type: zip
Old Sep 7, 2010 | 01:06 PM
Engine: L69
Transmission: BW T5
Re: BLM Cells 16 17 18 only in CLOSED LOOP?
Any thoughts? Or, as a last resort, any GM tuning gurus that you think I could ask?
Thanks!
Old Jul 13, 2011 | 06:15 PM
Adams Z's Avatar
Did you ever get an answer to your question? I have the same problem now.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Mark_ZZ3
May 24, 2018 01:02 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
3.8TransAM
Sep 27, 2015 08:37 PM
