ARAP best starting point?
Old Aug 31, 2010 | 11:04 PM
gmsoldier's Avatar
Car: 86 Iroc
Engine: 383 MR
Axle/Gears: stock 2.73
well hopefully you can see from the title, Im a newb to tuning. basically i was wondering if the ARAP bin would be the best starting point for my set up. computer is '165, xdf is $6E. the engine is a 355, 10.5:1 compression, heavily ported 882' heads, mini ram, 58mm TB, accel supercoil, hydraulic 221/230 @.50 .454/.454 112lca installed at 108, 30lb accel injectors, 1 5/8" headers, built 700r4 with 2500-2800 stall, 2.73's in the rear.....ANY advice or suggestions would be GREATLY appreciated
Old Sep 1, 2010 | 09:46 PM
gmsoldier's Avatar
Car: 86 Iroc
Engine: 383 MR
Re: ARAP best starting point?
nobody? lol i hope this wouldnt be considered prom begging or sumthin
Old Sep 1, 2010 | 10:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I would try it, but rework the timing table alittle. Its really aggressive. Works ok with most aluminum heads but with irons and your high compresion, i'd really back it down.
Max timing in that bin is limited to 41.8 degrees i think, the table has values up to 48 in some spots. So rework the table. I'd start with 30 deg total timing at WOT and slowly ramp down as rpms go down. Then in the cruise spots i'd smooth the table out and limit advance to the mid 30's for now as a start. Keep idle around 24-26 deg for that setup. With that smaller cam and high compression on iron heads, it may be very picky on timing. Be conservative with good fuel in the tank.
Working on a 230/236 cammed AFR 190 head 360" motor now that works very well on the stock ARAP settings for cruise idle and part throttle. WOT ran actually very rich so working on leaning it out. Car doesnt run what I thought it would but still far from finished.
Old Sep 2, 2010 | 08:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Recall that the max timing and max retard (min timing) are distributor limits. With the typical TPI base timing of 6* BTDC it is possible to have up to 48* BTDC at the crank. And a minimum of 2.5* BTDC minimum at the crank.
And what Orr said about ARAP spark timing being aggressive.
RBob.
Old Sep 2, 2010 | 08:25 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
True, from the last discussion on that I should have mentioned that its a distributor limit. From the datalogs you will only see 41.8 but based on how the bin code works, I guess its possible to see more than that at the crank.
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
onebadazzsrt
Aug 15, 2015 07:00 AM
