What does this section of code do?!?!
Old Oct 14, 2010 | 05:18 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Like the title says. It looks like what's stored to A and B is either overwritten or not used at all. Enlightenment, please?
Code:
D8D8:            BRCLR   L0036,#$08,LD8F2  ; BR IF NOT b3, ALDL MODE 4
D8DC:            LDAA    L0160
D8DF:            BITA    #$04    ; b2
D8E1:            BEQ     LD8F2
                                            ; ... Else
D8E3:            LDAB    L0162
D8E6:            CLRA
D8E7:            PSHB
D8E8:            PSHA
D8E9:            PULX
D8EA:            LDD     #$FFFF
D8ED:            IDIV
D8EE:            STX     L00D5
D8F0:            BRA     LD95A
Old Oct 14, 2010 | 07:30 PM
tequilaboy's Avatar
Re: What does this section of code do?!?!
It is a routine to modify the target AFR directly via ALDL Mode 4 and bypass the normal PE AFR calculation.
The value that is loaded into A (L0160) is a status bit that is checked before proceeding.
The value that is loaded into B (L0162) is the new AFR from the Mode 4 command message.
Old Oct 14, 2010 | 09:25 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Code:
D8DC:            LDAA    L0160
D8E1:            BEQ     LD8F2
                                            ; ... Else
D8E3:            LDAB    L0162
D8E6:            CLRA
D8E7:            PSHB
D8E8:            PSHA
D8E9:            PULX
D8EA:            LDD     #$FFFF
D8ED:            IDIV
D8EE:            STX     L00D5
D8F0:            BRA     LD95A
The value in the A and B registers (which is the 16 bit D register) is pushed onto the stack and then popped off of the stack into the X register. Then the D register is loaded with FFFFh and divided by the X register (this is the value that was originally loaded in A,B). Then the result is stored at L00D5.
So.....
L00D5 = ffffh/L0162
Hope that makes sense.
Old Oct 14, 2010 | 11:16 PM
bl85c's Avatar
Car: '85 maro
Ah, I'm reading it wrong then. Looks to me like what was loaded onto A was subsequently cleared then commanded to push to the stack. So why is there a clear A command before A is put on the stack?
Old Oct 15, 2010 | 07:28 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Sorry, looks like i got that slightly wrong.
B is loaded with the value from L0162 and A is cleared to zero. These 8 bit values are pushed onto the stack B first then A. They are then popped off of the stack into the 16 bit X register (high byte first) so effectively X (16 bit) contains the value from L0162.
So,,,
L00D5 (16 bit) = ffffh/L0162
Old Oct 15, 2010 | 09:01 PM
bl85c's Avatar
Car: '85 maro
Thanks, that helps me with what I'm writing. Finding enough space for this hack is getting tedious.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
FormulaEngland
Sep 30, 2015 01:50 PM
