Pinout Adressing?
Old Nov 2, 2010 | 12:06 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Pinout Adressing?
How do you figure out what adresses are for what pins in the ecm? Ex. #$A0 is the adress for pin B12 in the '165 ecm. Does someone have a chart? Thanks.
Old Nov 3, 2010 | 11:30 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Pinout Adressing?
Pretty much need to make a listing of each output/input and scour through the code to find the controlling bit or address and document it.
In some cases there are intermediate controlling bits that are set to configure the output to be controlled by different routines.
Mode 4 can take over a bit while the main code operation is ignored.
Can drive you crazy tring to find the end point of control in some cases.
Using the output can sometimes be easier letting the existing code turn it on/off by setting the controlling bit. Otherwise you have to find all other related code and try to remove it so you have exclusive control of it.
You can't turn on the output directly unless all other controlling bits are removed that are turning it off.
Items like EST enable are set by communications routine at address 4002 (in $8D anyway)
Those items can be difficult to find because of indexed addressing modes.
Old Nov 3, 2010 | 08:09 PM
bl85c's Avatar
Car: '85 maro
That's what I was afraid of. So what to do with unused pins like B6? So far I can't find anything that points to it.
Old Nov 4, 2010 | 08:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Pin B6 is a frequency input. It ends up going to the PWM ASIC, so will be in the $3F00 address range. Most likely it will be a counter such as used for DRPs.
Easiest way to figure out the address is to bench the ECM, apply an input to B6, read and display the contents of the registers in the $3F00 range. See which one responds to B6 input.
IIRC, $32 can use either a voltage or frequency MAF. So perusing that code may show which address that register uses.
RBob.
Old Nov 4, 2010 | 10:24 AM
bl85c's Avatar
Car: '85 maro
Alright thanks. I was planning on making a bench anyway, now I have a reason to do it.
Old Nov 4, 2010 | 11:34 AM
JP86SS's Avatar
Some Bench reference info and discussions.
https://www.thirdgen.org/forums/diy-...nch-calcs.html
and
https://www.thirdgen.org/forums/diy-...est-bench.html
I havn't added the "drain" to common for the VSS output to allow it to cross zero for the magnetic yet. Been just flipping the bit to optical style and using it as is. Works pretty good but would like to try the VCO implementation.
Old Nov 9, 2010 | 12:46 PM
BIG 'G''s Avatar
RBob.
IF I understand this corectly the aldl stream needs to modified to read the registers and the xdf modified to display the registers when testing a pin.
InfernalVortex
Apr 20, 2021 11:31 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
funstick
Jul 15, 2002 10:08 PM
TransAm86
Sep 24, 2000 09:35 AM
