EBL NAlpha tuning?
Old Nov 19, 2010 | 10:17 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
EBL NAlpha tuning?
Hey guys I was wondering what exactly do the NAlpha tables do? I was wondering what would happen if I smoothed them out. I was checking out my MAP KPa vs RPM & TPS and those tables look a little dicey. What can I do?
Old Nov 20, 2010 | 08:17 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: EBL NAlpha tuning?
In your case they should be (are) doing nothing.
They are only used when running in N-Alpha mode.
Play with them all you like, just don't turn them on.
N-Alpha is to remove somewhat the MAP sensor's contribution from engine fueling, used only when true MAP readings are not usable.
Enabled with Option Word 1 bit 7.
Old Nov 20, 2010 | 08:53 AM
I see, what benefit would there be to use this mode?
Old Nov 20, 2010 | 09:05 AM
xch3no2's Avatar
Transmission: TH400
You could use N-Alpha if your MAP sensor provided unusable reference,
or there was no MAP at all.
It's benefit is that of a workaround, something you might have to use if say a very radical cam were installed.
Rocket-Doc
Nov 14, 2015 02:08 PM
