EBL .bin settings
Old Dec 6, 2010 | 02:49 PM
Ronny's Avatar
EBL .bin settings
I am asking if these changes were warrented. Changes done two years ago GM 7.4L TBI. GM 80 lbs injectors runnin 20 lbs fuel pressure. I presume changes done due to slower opening time of my injectors?
ron.bin ... EBL.bin(305 auto)
PRP prop gain duration idle 3.00 ... 5.00
" offset 14.0 ... 20.0
IAC B9in idle speed 700 ... 0
Inj correction multiplier 12.8 ... 7.02
" offset 14.4(??) 442.5 ... 396.80
PRP gain multiplier vs airflow (example 80 grams/sec) 50 .... 100
Thanks.
Old Dec 6, 2010 | 09:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL .bin settings
Thanks.
With the exception of the B9In idle speed the changes are legit when larger injectors are in use.
RBob.
Old May 24, 2017 | 03:50 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
So guys you talk about changing setting for larger injectors, how do you know this has to be done and how does one figure out what to set them to?
Old May 24, 2017 | 09:06 PM
Ronny's Avatar
TBI settings not published. TPI are published . basically a educated guestimate. My idle speed IAC only allowed to increase the idle speed. TSS set min. GM settings for 7.4L TBI may be hacked but many of us run mod 350/383
ps tko 600 going this week
Old May 24, 2017 | 09:43 PM
Rocket-Doc's Avatar
I think I have found what I was looking for. But I should assume that this was already done in the 3001.bin file correct?
Re: 454 tbi
Quote:
Originally Posted by freaky View Post
ok setting up my tune fore the 454tbi an i want to make sure i understand this .i have #55.0 an i'm putting in 80.5 so do i minus the tables by 31.5% ? or do i just take 80.5 an subtract 55 from that leaving 25.5 .then subtract the values by 25.5 from the tables you listed ? ?
thanks ...
55 / 80.5 = 0.68, multiply the table values by .68
RBob
Old May 26, 2017 | 07:39 AM
Rocket-Doc's Avatar
I found some original bin files on http://gearhead-efi.com/gearhead-efi/bin/
I think I'm going to get an excel chart going to see if the math all works out. The few I had already looked at like the 2025 and the 3001, had very odd numbers in the tables.
1992Vortec
Aug 31, 2015 08:05 PM
hydrolic144
Aug 29, 2015 04:14 PM
soarestransam
Aug 24, 2015 08:15 AM
mustangdmurder
Aug 21, 2015 07:17 PM
beast94
Aug 20, 2015 06:44 AM
