BLM Tables?
Old Dec 7, 2010 | 10:01 AM
chevyracer8262's Avatar
BLM Tables?
How exactly does the blm tables work? I know I've read alot about how the magic number for the blms are 128, why is that exactly? Is the 128 BLM like the Lambda=1 referance when tuning with a wideband o2? I've tuned a few different vehicles using tunerpro and tunerpro v5 and am curious about how the blm table actually functions...
Thanks,
Old Dec 7, 2010 | 11:57 AM
Ronny's Avatar
Re: BLM Tables?
Lambda +1.00 is stoich . All fuel is being consumed. A/F is spot on. 14.3 for E10 and 14.7 for reg gas E85 I think is 9.+
BLM is the block learn mode.
02 feedback moves the integrator(128 + -). Short term change.
After INT moves it may trigger a long term BLM (128+ -) change arriving at stoich.
BLM is affected by environmental temps and mechanical changes in engine.
see stickies above...
Old Dec 8, 2010 | 08:34 AM
Re: BLM Tables?
ok i read up on the blm tables and now understand how they work, now my next question is how would I change the afr that it's trying itself to correct to read a different afr rather than 14.7? I'm going to be running an 8625 pcm in pfi mode using the 0$ maf code so I'm trying to learn as much as I possibly can before i get my engine together.
Old Dec 8, 2010 | 01:49 PM
Ronny's Avatar
Re: BLM Tables?
not sure about your def file but mine has a constant called "stoich". It is set stock at 14.7. I reset mine to 14.3. I believe 14.3 is richer than stoich EVEN though I run E10.
Also 02 swing points rich/lean median. I moved them higher by 10% .
Old Dec 9, 2010 | 09:30 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: BLM Tables?
There's hardly any 'bandwidth' to play with using a nbo2. The switchpoint is between roughly 14.9 and 14.5. Check this out.
Old Dec 9, 2010 | 10:08 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
Re: BLM Tables?
Easiest thing to know about BLM is you want them hovering very close to 128 in all conditions. Getting exactly 128 is nearly impossible. Some of the best tuners can hardly do it.
Old Dec 10, 2010 | 09:31 AM
Ronny's Avatar
Re: BLM Tables?
There's hardly any 'bandwidth' to play with using a nbo2. The switchpoint is between roughly 14.9 and 14.5. Check this (Enough Closed Loop Info to be Dangerous) out.
that is why my calibrated WB shows 14.5-1 14.9 at cruise. DE and DFCO is disabled.
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
