Problem with burning/erasing chips with Autoprom
Old Jan 15, 2011 | 10:37 AM
86Chicken's Avatar
I've used this AutoProm a few times in the past and it seemed to work but I haven't needed to use it for a year or so. Today, I needed to make a few quick changes and I can't seem to get a successful write to the chip.
For now, I'm just trying to erase a 27sf512 through Flash&Burn. The AutoProm is connected to the laptop and F&B seems to recognize it. When I choose Erase Chip it returns Succeeded. But, when I then choose Blank Check it says the chip is not blank. I've tried this on 3 chips with the same results.
I was also never able to get a bin to write and successfully verify either.
Does anyone have any ideas?
Thanks!
Old Jan 15, 2011 | 08:38 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Re: Problem with burning/erasing chips with Autoprom
Try inserting the chip correctly.
The notch should face the ZIF handle and the chip should be pushed furthest from it.
Old Jan 15, 2011 | 08:45 PM
86Chicken's Avatar
That was how the chips were oriented during the failed attempts.
Old Jan 15, 2011 | 10:18 PM
Car: 87 T/A
Strange, it should work.
Get with me Monday if you like and I can do some troubleshooting for you remotely if needed.
Old Jan 16, 2011 | 09:22 AM
86Chicken's Avatar
Thanks! I may have to get with you on this.
I did a little more playing this morning and it's intermittently working.
I decided to try swapping USB cables but it didn't make a difference right away. But, after 3-4 tries it started working again. For fun, I swapped to the previous cable and it was still working. I could erase and blank check a chip as well as program and verify without error. So, I decided to try a different chip and it went back to not working for awhile. Restarted F&B and after a few failures, it's back to working for the moment.
Thanks!
Dale
Street Lethal
Apr 30, 2019 12:14 PM
inferno15
Aug 29, 2015 01:48 AM
ambainb
Aug 29, 2015 12:43 AM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
