regular gas and tuning
Old Jan 24, 2011 | 12:55 PM
slickfx3's Avatar
Car: 1989 Chevy Corvette
Engine: 383 SuperRam 10.7 AFR 195 220/229
Transmission: Fancy Smansy 87 Corvette 700r4
Axle/Gears: 3.33
I have heard that regular gas if understood; is not really a bad choice, given it has fewer carbon buildup producing additives, such as anti- knock, is more volatile etc.
since all here is able or would like to be able to manipulate tune, is it conceivable to tune only for regular low octane gasoline for a highly modified tpi motor and live to tell?
and would the performance difference be large?, I really don't care about every last bit of horsepower, I like responsiveness and lower fuel costs wouldn't be a bad thing for me either.
is it as simple as dialing back the spark advance table? to take car of the knocks?
Old Jan 24, 2011 | 01:26 PM
CamaroIROC88350's Avatar
Re: regular gas and tuning
I'd run on a higher octane fuel to be on the safe side. Don't want to blow up your engine!
Old Jan 24, 2011 | 03:00 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
depending on how the motor has been modded, you can tune it to run on regular without a problem. but you very well may see a big drop in both performance and fuel mileage.
much over 9.5 with iron heads, it would need better fuel.
if the quench isn't right, it would need better gas and will never run to its full potential, even with good gas.
Old Jan 24, 2011 | 03:10 PM
slickfx3's Avatar
Axle/Gears: 3.33
AFR 195 street heads, 10.7 compression,
I like your term "full potential", I want better gas mileage....
Old Jan 24, 2011 | 09:15 PM
DENN_SHAH's Avatar
with aluminum heads, i don't know what the limit is for regular gas. i would guess if you not over it, your very close to it.
hopefully some of the guys that have ran aluminum heads will jump in.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
