Re Boost with 7730
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Re Boost with 7730
Hi all,
I have a question. I have a 92 7730 ecm Hard wired Innovate WB and am currently running SAUJP V5. Is this Bin/ECM able to run a boosted application?
I am tossing around the idea of throwing some boost at it but i worry about fuel control...i DO not want to use a fuel management control, i want to be able to control the tune via my ECM is this possible? BTW it would be a Procharger, Stage 2 Intercooled 3 core, on a modded Super Ram 350. Also i have a Racetronix high output fuel system in place...i hope it will flow enough fuel...opinions welcome..thank you. GTA
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Re Boost with 7730
the 730 can run code $58 or $59 which are boost capable with 2-3bar maps. SAUJP stuff, I have yet to see anyone use it with boost in mind. There was a claim of someone here who developed it but never seen results or seen the modifications.
Car: 1992 GTA
Engine: running
Axle/Gears: both
Thanks Orr,
Has any one done exactly this...run a 7730 ecm and code 58/59? Which is better i know very little about the code 58/59 stuff i am much more familiar with
AUJP/SAUJP....i must do more reading on this 58/59 stuff. what about types of injectors ( bigger #42 ) can the 7730 ecm drive safely?? ....
Car: 89 Iroc-z
Transmission: TH400
I'm doing that exact thing on my car right now. i was MAF 165 and I converted to 730 and plugged in the code $59 chip and went to town. Runs great. I have 80lb injectors and it idles fine although abit higher than I want (~1000 rpm but the car likes it when I should beable to get down to 800)
The code is abit different than any of the 8D stuff you may be used to but if you can tune MAP you can tune code $59. I never tuned a map car til i started on my 401 twin setup....
There are a few things to change in the base bin file you can get on code $59.org since its designed for a V6. few changes to make it a V8 and go from there.
There are a few things to change in the base bin file you can get on code $59.org since its designed for a V6. few changes to make it a V8 and go from there. Thread Starter
Car: 1992 GTA
Engine: running
Axle/Gears: both
Ok, silly question time..
If i want to run 9 psi boost and use SAUJP ( retard spark tables and add fuel via ve ) would this not work as well? I know the VE runs out at 100 KPA and in a boosted application VE will go higher? would it still not work out in the end?
I do have a WB that shows in my data log live info, as long as i use big enough injectors i should be ok..?? am i wrong in thinking this...Code 59 kinda scares me
I dont want to repin or lose my ccp and other options....GTA
Transmission: 5-speed/T-5
You can run a 1 BAR code with boost, but fueling will not be matched to actual manifold pressure, since you can get to 100 KPA at 4000 RPM, or you can get to 200 KPA at 4000 RPM, depending on conditions and transitions through driving around the same cells.
The only way to really run a 1 BAR code with boost and have fueling pretty close under all manifold pressure conditions would be to use an FMU.
Spark timing will also be effected in a similar fashion.
I have also ran $59 with a '7730. I'm using a '7749 currently, since I plan to run low-Z injectors and need the two injector drivers.
Car: 1992 GTA
Engine: running
Axle/Gears: both
Thank you for the replies so far,
So what would you folks suggest as my best option, I want to run this procharger on my car...i'm not too crazy about the FMU...I would rather control the fuel in the ecm. What exactly would i need to aquire to run this? Code 59?
Is there rewiring? Or maybe i should just use the supplied FMU? hmmmm...
You will need a 3 BAR MAP sensor (code requires a 3 BAR), and maybe a pin change or two.
I think there was a change for the TCC when going from $8D to $59. Details can be found on the $59 site. www.code59.org
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I also run $59
there are a few options using CCP with code59.
See signature of last years testdrive
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
-G1 adapter
-Ostrich 2.0
-ALDU1+CABL1 combo
-Tuner Pro RT (There used to be a discount for the registration of Tuner Pro when buying an Ostrich, so you might want to check into that.)
https://www.thirdgen.org/forums/post...347-post6.html
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Car: 1992 GTA
Engine: running
Axle/Gears: both
Ok, i'm back after some searching...and more questions of course!
1. My current 7730 ECM has the WB wired into pin F14 this can remain there and will work with code 59 correct?
2. I have found 2 conflicting stories re Code 59, One says no pins need to be moved, and another says a few do, which is correct and what pins are they?
3.I have down loaded the XDF/ADS from Code 59.org are these the correct ones for V5?
a. XDF/ Code 59_3bar_1.6_V18.XDF
b. ADS/ Code 59.6 Beta TP5 ONLY.ADX
4. Exactly what options do i lose in going from SAUJP to Code 59?
I am currently all emissions legal and really wish to remain so.
5. I see a lot of the Code 59 users are running in open loop all the time, Does Code 59 use a WB feed back so it can operate in closed loop?
Thank you, that's all for now ....GTA
b. ADS/ Code 59.6 Beta TP5 ONLY.ADX[/quote]
Yeah those will work, though I think there is a non beta version of the ADX now.
Car: 1992 GTA
Engine: running
Axle/Gears: both
Six, thanks for the reply.
I am planning on just uploading the Code 59 into my 7730 ecm, This is the reason for all the questions....I think this may be the best soultion to running boost on my car. Has any one here run a combo like this and retained all of their emissions equipment and functions? With Code 59
Car: check
Engine: check
Transmission: check
As for $59, I know that the EGR has been patched so it works with an 8-cylinder engine. However, I don't believe that CCP or dual solenoid A.I.R. has been added.
The most straight forward approach is to use an EBL P4 Flash. This will run all emissions equipment (EGR, CCP, & A.I.R.), plus it is set up for the dual fans and A/C control. No swapping of wires required. And provides for a 1-bar, 2-bar or 3-bar MAP sensor.
RBob.
Car: 89 Iroc-z
Transmission: TH400
I cant comment on the emissions stuff or the pin swap for the 700r4. I dont use any of those things anymore.
I also havent tried wideband closed loop as I dont think my tune is close enough yet either.
Hmm thts newer than the one I got. Think its time I get back on code59.org
Car: 1992 GTA
Engine: running
Axle/Gears: both
RBOB, hi
With this EBL P4 Flash I would be able to retain all of my SAUJP functions and run a boosted application? How exactly does this work? Do i just purchase one of your your ECM's replace my 7730 with this upload the SAUJP bin and go? Is it that simple? I really like the SAUJP stuff, but i kinda want to look at going boosted in the near future, so is this a direct plug and play set up ? My car is a 1992 7730 ecm and i am currently running a moates adapter Ostrich 2.0 and a wireless BT, i like what i see....please tell me more?
oh and i also have a innovate WB that is already hardwired into F14 and it works perfectly with TP/RT V5...which is what i am running with a windows 7 lappy......GTA
Car: check
Engine: check
Transmission: check
RBOB, hi
Tuner Pro is used to make changes to the calibration, which is then flashed in with the WUD. Can also read calibrations out via the WUD.
You can purchase a ready-to-go ECM with the EBL P4 already installed. Can send in your ECM to have us do the install, or do the install yourself. The install guide is on our web site.
The EBL P4 Flash system supports all of the factory emissions equipment. I'm not sure which features of SAUJP you like, but the EBL has VE and fueling boost tables to 8,000 RPM, will display the WB reported AFR via the WUD, has a trip display that shows miles/Km traveled and fuel consumption.
RBob.
Car: 1992 GTA
Engine: running
Axle/Gears: both
I think, I have found my answer
There is going to be some tuning equip for sale soon. Thanks GTA
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm not sure if he ever released it to public domain.
One day I'll probably try either an EBL or a Megasquirt. I used to think the MS was lame, but the newer software is just absolutely amazing and light years ahead of even the super expensive aftermarket stuff.
Some, like a younger me, will argue that OEM code is better for street cars and that is probably true, but the last few combos I build won't even run feedback/closed loop fueling so a lot of that stuff is 'out the window'.
The next car I build, will probably be a first gen with a stupid twin turbo small block, so really all we care about is cold starts and keeping the rings from sticking to the cylinder walls
-- Joe
Car: 89 Iroc-z
Transmission: TH400
-- Joe
-- Joe
Everything else really isnt needed
. I dont run closed loop either.But I'm sure the little functions all help to create a great driving experience..IAC/TPS control and the AE functions all help with driveability.
I'd like to try the $8D code for boost tho, even tho $59 does everything I need so far.
Fixing up $8d for use with boost is as simple as locking down the Baro update so that it cannot change while the engine is being run, only during key up should it record Baro. Once you accomplish that, the map sensor in use is irrelevant and adressing the XDF to reflect the map sensor is all thats is required.
I never got all the hoopla around this. Maybe I'll post up a binary later.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
My approach would be to run the 2bar on a different input, read the value in, spit a multiplied value to the memory address 99.9% of the $8D code looks at, and just create a bpw multiplier table when the map is > 100kpa.
Too bad nobody has a mask written in C.
-- Joe
You need to make sure you don't miss every single condition that references MAP voltage, and half them all. Without a darn perfect commented decompile, I'd be too weary of missing something.
-- Joe
-- Joe
I just got done doing another one, I'll post up the binary and XDF. Its not a big deal to do this.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Interested to see that.
Can you throw some logs in as well.
thx,
Jp
thx,
Jp
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm also interested in seeing a boost enabled $8D.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
$58 had great spark control under boost, but it's boost fueling was ultimately an FMU
-- Joe
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by funstick
Fixing up $8d for use with boost....
I am only currently using a 2bar sensor, but I geuss one could use a 3bar, but the airflow terms get even screwier. But the point is, this does work, I have done it many times and the customer is always happy. that siad the fueling gets a little grainy with some .25 point deviations at low airflow amounts, but there becuase the airflow term is limited to 255grs/sec and without doing serious coding work , read not worth the effort, its as good as most after market ecu's and its extremly budget.
So its not the holy grail, but its also a workable solution. It doesn't have to be perfect, it just has to be good enough.
F77/F71x is still enabled, and it too has been expanded. By all rights, F77x could be set to a multiplier of 1.00 all the way through and use just F29x table to control all fueling.That reminds me, I need to see where my F77x table is set in the higher boost that I'm hitting now, could explain a few things... lol
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
They did expand the VE table, with fueling points up to 300 KPA, much better than the FMU effect of $58.
F77/F77x is still enabled, and it too has been expanded. By all rights, F77x could be set to a multiplier of 1.00 all the way through and use just F29x table to control all fueling.
F77/F77x is still enabled, and it too has been expanded. By all rights, F77x could be set to a multiplier of 1.00 all the way through and use just F29x table to control all fueling.That reminds me, I need to see where my F77x table is set in the higher boost that I'm hitting now, could explain a few things... lol
$8D with a 2-bar VE table could be quite useful if I get bored of my 412 SBC and decide to put big pig chamber heads on it, a smaller cam, and a stupid big blower.
-- Joe
Car: 89 Iroc-z
Transmission: TH400
I had thought at one point they expanded the VE table, and disabled the BPW boost multiplier.
By all rights, F71x could be set to a multiplier of 1.00 all the way through and use just F29x table to control all fueling.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 89 Iroc-z
Transmission: TH400
For some reason with the one table called "egr vs base pulsewidth" or whatever it is, thats suppose to be like your "injector" constant. I left it as it came from the base code$59 bin. For the new setup i lowered it abit but it does not match my injectors value.
So with that i just scaled the v6 bin which was set for 60lb injectors. Initially i multiplied everything by .75 since 60/80 is .75. Eventually i got the car to fire and i got an idea what idle map was and what ve it needed to be. The steps between cells sucked from the v6 bin so i took a 730 tpi l98 ve table and copied it in the scaled it down til the idle ve matched about what i found from the v6 bin.
My new setup idles at 1000 rpm and 64 kpa. Ve value is only 23-24. By 101 kpa its only in the 40's or so by 4000 rpm. 60 at 140 kpa and 4000 rpm so far but its rich! So i am not exceeding 100 yet.
My old setup even at 215 kpa never saw over 70 ve for whatever reason
"VE" is really a misnomer, it's not really a representation of actual engine volumetric efficiency, it's just what the tables were called.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The problem here, is years of trying to accept that $8D has a cylinder volume constant, an injector size, then a table that tries to represent actual VE. It's quite a reasonable theory, but then when you say $59 has an 'expanded' VE table to 300kpa, it's only possible if the VE number can exceed 100%.
Since it appears you use 0-100 over the whole table, I guess naming it "Fuel value" would be more appropriate, although I think at this point I'd prefer "INJ duty cycle" like some of the aftermarket.
Off hand, if you have a handle on the CFM requirements of a motor/cam combo, can you calculate boost from compressor CFM ? I'm curious exactly *how much* boost a P1SC would add to my 412, and if using $59 is worth it over modified $8D.
-- Joe
Car: check
Engine: check
Transmission: check
RBob.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I have 843cc per cylinder, so at 100KPA manifold pressure am I not at 100% VE?
Surely I should be > 100% VE under any boost level, since I've filled and exceeded 843cc of air at barometric pressure.
Or maybe I'm looking at this wrong...
-- Joe
Originally Posted by anesthes
Off hand, if you have a handle on the CFM requirements of a motor/cam combo, can you calculate boost from compressor CFM ? I'm curious exactly *how much* boost a P1SC would add to my 412...
Car: check
Engine: check
Transmission: check
I don't get what you are saying. If the pressure is anything other than baro, than isn't VE out the window?
-- Joe
-- Joe
The VE will be 100% when the chamber pressure becomes the same as the intake manifold pressure. If the manifold pressure is 50Kpa and the chamber pressure ends up at 50 KPa, then the VE is 100%.
If the chamber pressure ends up at 25 KPa then the VE is 50%.
The key to all of this is that the MAP value is used as part of the PW calculation. That is the part that makes the VE relative to manifold pressure.
There are stock GM TBI calibrations (Caprice L05 engines) where the VE drops off as the manifold pressure goes over 85 KPa. If VE was relative to baro pressure this wouldn't happen.
There is a discussion of this on a thread someplace here on the DIY_PRO board.
Back to S/C'ers, if the manifold pressure is 200 KPa and the chamber ends up at 200 KPa, then the VE is 100%.
This is likely why GM used a PW multiplier table. Just use the 100 KPa column of the VE table which is going to be real close. And add some fuel to drop the AFR via the multiplier for the boost.
RBob.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
A little confused with the question, do you mean that you are trying to calculate the Volumetric Efficiency of your engine with the supercharger beforehand, then use that calculation to determine how much boost it would take, or is taking, the supercharger to accomplish this? Are you worried that the smaller P1SC compressor map will hinder performance of the larger engine? There are a number of equations that will help figure this out, but there are also a lot of variables though...
We also roughly know the CFM of the supercharger at a given pulley speed.
How do you calculate the boost pressure that the manifold will see?
If for example, I knew that the combo would make 8psi I'd probably make different calibration and fuel system decisions than if it showed 15 or 20 psi.
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
In the carb days VE is relative to barometric pressure. In the GM EFI ECMs VE is relative to the intake manifold pressure.
RBob.
RBob.
So you really can't actually calculate VE since you have no way of knowing what the pressures are actually in the cylinder, so the VE numbers are theoretical based on cyl volume, map value, and target AFR..
Hrmm..
So which method do you prefer? A VE table that stops at 1BAR with a pulsewidth multiplier for > 100kpa, or a VE table that goes 2-3BAR ?
-- Joe
-- Joe
-- Joe
Car: check
Engine: check
Transmission: check
Need to be able to subtract as some engine set ups have the VE dropping like a rock as the manifold goes into boost.
One thing to remember about boost is that it is a result of restriction to flow.
RBob.
So we know the airflow requirements at RPM of a given engine because we know the head flow, displacement, stroke, and camshaft timing points.
Car: 89 Iroc-z
Transmission: TH400
A fuel PW multiplier table from 100 Kpa through 200 or 300 KPa along with RPM. This table is used to either add or subtract from the PW.
Very interested in the second comment about being able to subtract as some engine setups have ve dropping like rock as goes into boost.
I am just experiencing that now and I thought it was odd but figured it was due to 2 things...my new injectors being so much larger than before and the fact that at 4-5psi my second fuel pump kicks on and I think its spiking my fuel pressure, thus increasing fuel amount.
My VE table in $59 is steadily increasing til about 120 KPA then for some reason its too rich after that so it kinda flatlines abit. Then increases a slight amount at 140-150 kpa. Very small steps in VE compared to 90-120 KPA areas.
I was starting to see things get PIG rich at 3500-3600 and 135-140 KPA. Off the charts rich. Pulled so much fuel today I cant believe it and its still rich. Cars feeling stronger with each tune but fuel requirements doesnt seem to line up with what I expected especially compared to the old combo. VE was flat up top on old setup but increased to 150kpa for the most part before leveling out.
The richness is so bad I enabled the boost multiplier table and instead of making everything 1 like before, at 132 KPA I have .98 and at 148 and higher its .92. Its pulling 8% out of the VE table for KPA's above 148, and still my VE table is flat after 120 KPA. If I didnt do this I'd have a VE table nosing downward after 120 KPA column
Its an ODD map to look at but its giving the motor what it wants/needs. Just curious as to why that would be the case, because with my heads/cam/intake, i'd expect peak TRQ to be in the 4500 rpm range and its not looking that way on my graph so far. It went rich there instead of lean
I am just experiencing that now and I thought it was odd but figured it was due to 2 things...my new injectors being so much larger than before and the fact that at 4-5psi my second fuel pump kicks on and I think its spiking my fuel pressure, thus increasing fuel amount...
And I wasn't feeling too smart, now I have a headache.
