delta TPS + MAP AE
Old Jan 28, 2011 | 01:49 PM
Ronny's Avatar
delta TPS + MAP AE
Code:
Runtime   RPM  MPH MAP TPS    sPW  dTPS  tpsAE  dMAP   mapAE    aePW
00:00:44 1750   22  33   2  1.160  0.0  0.000    0.0    0.000      0.000
00:00:44 1700   22  34   3  1.709  0.8  0.137   0.0     0.000     0.458
00:00:44 1650   22  37   5  1.678  1.2  0.107   2.8     0.000    0.275
00:00:44 1650   22  38   5  1.770  0.4  0.107   4.4     0.000    0.458
00:00:44 1650   22  40   7  1.923  1.2  0.107   5.3     0.000    0.732
00:00:44 1675   22  43   7  2.350  0.8  0.107   6.6     0.076    1.083
00:00:44 1650   22  45   8  2.289  0.8  0.076   8.8     0.092    0.626
00:00:44 1700   22  47   9  2.808  1.6  0.122   8.4     0.092    0.732
00:00:44 1650   22  48   9  2.380  0.8  0.107  10.9     0.092    0.626
00:00:44 1625   22  51  10  2.899  0.8  0.107  11.3    0.107   1.190
00:00:44 1650   22  54  11  2.838  1.2  0.122  11.3    0.107   0.916
00:00:44 1675   22  57  14  3.204  2.0  0.153  15.0    0.137   1.419
00:00:44 1700   22  62  15  3.235  1.2  0.107  16.6    0.137   0.793
00:00:44 1675   21  64  15  3.082  0.4  0.076  18.4    0.122   0.458
00:00:44 1675   22  65  15  2.899  0.4  0.000  16.3    0.137   0.504
00:00:44 1675   22  65  15 2.838  0.4  0.000  13.4   0.122  0.397
00:00:44 1725   22  65  15 2.777  0.4  0.000  13.8   0.107  0.397
Take a look at runtime line # 2. There is the onset of AE.
Delta was qualified for TPS AE at .8 as TPS AE resulted at .137. It shows with AE of .46. right?
Line 6 delta was met for MAP AE at 6.6 and AE MAP resulted at .076. right?
Far right column is AE "pulse width'.
sPW which i believe is synch pulse width is a larger # than the total of AEpw values which I presume also includes the VE fueling. correct?
are the AE values also synch pulse width or usec?
Something does not add up.
Edit: My table got misaligned. Damm
Old Jan 28, 2011 | 04:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: delta TPS + MAP AE
Columns are a little better.
The aePW as shown in the last column is what is added to the sync PW. It is in milli-seconds (msec). The sPW is the final as programmed to hardware sync PW.
tpsAE is in msec, as is mapAE. These are the results of the look up table.
Between them and the aePW, the RPM & CTS compensations are made.
Note that the data doesn't always line up. This is due to the ECM running this routine 80 times a second. And the EBL sending data at 17 times a second. So as a variable is output via the EBL, the ECM is changing other variables associated with it.
Also, not all variables get re-calculated that often.
RBob.
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
ULTM8Z
Sep 16, 2015 09:15 AM
