cruising idle issue
Old Feb 9, 2011 | 01:20 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
cruising idle issue
So, I've been living with this issue and just can't pin point the problem.
Car-
1990 tbi
mild cam
single plane low intake
shorty headers
5 speed
7746 ecm - using tunerpro
I can drive the car cold/warm/op temp and between shifts it fall to 1k rpm - which I like. As I speed up, 30-40 mph, if I place into neutral - it revs to 1500-1700rpm until I come to a stop. Once stopped, 1-2 seconds later, drops to 800-900rpm(as where I have target idle set). If I'm on the highway, exit and coast @ 70mph, it holds to 1700rpm, then slowly falls to 1500rpm and holds until I stop. Any clues, suggestions would be much appreciated.
Old Feb 11, 2011 | 03:05 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Re: cruising idle issue
nobody??
Old Feb 12, 2011 | 08:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by monkihead
nobody??
Throttle follower.
RBob.
Old Feb 12, 2011 | 01:09 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Thank you sir! Didn't even see that there.
Old Feb 15, 2011 | 05:54 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
I lowered it all the way down, and it still does it.
Old Feb 16, 2011 | 08:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Which ECM? The stock '8746 or the '7747?
RBob.
Old Feb 16, 2011 | 10:02 AM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
I'm using the 8746. I drove it watching the idle counts and realized I had it set way too high for engine temp. After lowering it, the throttle follower worked. Thank you sir - without seeing that I would be chasing my tail for another week.
specialized
Jun 18, 2022 09:26 AM
bamaboy0323
Sep 3, 2015 06:07 AM
perZ
Aug 21, 2015 05:51 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
perZ
Aug 15, 2015 01:17 PM
