No ECM control of timing
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Running the EBL flash. It isn't controlling the timing. The only timing I have is initial timing, with or without the bypass unplugged. When I do unplug the EST bypass, I get the CEL, and timing is still the initial at the distributor. With the EST plugged in, still get only the initial timing. Replaced the module, but nothing changed. Think it could be a bad pickup coil?
Car: check
Engine: check
Transmission: check
Re: No ECM control of timing
The problem has been worked out. Don't get crazy with the initial timing.
RBob.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
