Question for you tuners.
To make a long story short, my tpi vette used to have a blower on it. When I got it, it was gone and I returned it to to a naturally aspirated setup. While my chip is out for reprogramming, Ive discovered the car has a few other mods, full roller rockers, adjustable FP regulator, big fuel pump maybe a 52mm TB, and 30lb injectors- possibly even a cam swap.
My question is, I want to run the car as close to stock as possible with what I have on hand. Is it possible to tune the prom properly to run the motor leaving the 30lb injectors in? I have everything back together, no stock injectors available and just want to run the motor to make sure its healthy before I get too far.
Can this be done? Can a decent tuner account for the larger injectors, Or should I start disassembling it all and put my projection setup on, or easier yet- just carb it. Thanks in advance.
Re: Question for you tuners.
Its converted to SD. I know what your saying about datalogging, but Im not even near that point yet, I just wanna get it to run half decent. Im not even sure the motors ok. Tuning later.
Transmission: 5-speed/T-5
You're missing the point.
To get it to run decent, the tune has to be correct for the engine combination, one of the large parts of getting that to work is through datalogging, even if it just for starting.
To answer your original question, tuning for larger injectors is one of the easier things to do in most cases (IMO), since there are usually constants or basic tables available to adjust for this.
Thanks six shooter, I know what you are saying- but I think you are missing the point. I bought the car(cheap) only taking the POs word that the motor was ok. I just want to see if it runs without knocking or anything catastrophic. I have no reason not to believe him, as everything seems to done properly, but now that its back together 100%, Id like to try to start it. The memcal was rewrote for the blower, so its out to be recalibrated for stock. The tuner wants all the info I can give him.
I just wanted to know if it was do-able, and you did answer that it is. After I find out its OK, then we can perfect the tune. If not- Im making serious changes to the setup and that TPI is history.
Thanks.
Thanks.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Use a stock calibration as a starting point and just set the injector constant and injector offset to what they should be for your injectors. Turn the key, and see what happens. If its close to stock, and has a stock calibration updated with the info for your injectors, then you should be good to go. The PW at idle may be a little short, but it will probably still work good enough just to see what your dealing with. The worst that will happen is that it wont run well if it has a large cam. But, at part throttle, it should be good enough to at least make sure the engine works.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by jeff355
Ive discovered the car has a few other mods, full roller rockers, adjustable FP regulator, big fuel pump maybe a 52mm TB, and 30lb injectors- possibly even a cam swap. My question is, I want to run the car as close to stock as possible with what I have on hand. Is it possible to tune the prom properly to run the motor leaving the 30lb injectors in? I have everything back together, no stock injectors available and just want to run the motor to make sure its healthy before I get too far. Can this be done? Can a decent tuner account for the larger injectors....
Thanks Street Lethal. Its all new to me, but Im willing to learn. I actually got a holley projection4, with the car, and since then scored a Haltech ecu for it if I actually want to start make changes away from the stock setup. Im willing to learn, but would just like to hear it at least idle, with the GM ecm, then I will go from there.
So, its relatively easy to adjust for the 30lb ers even on a near stock engine from what you are all saying. I just hope it runs. I should have the chip back this week...
So, its relatively easy to adjust for the 30lb ers even on a near stock engine from what you are all saying. I just hope it runs. I should have the chip back this week....
