Linux/Ubuntu TunerPro RT
Old Mar 5, 2011 | 01:02 AM
complete loser's Avatar
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
It appears that TunerPro RT installs and opens in Ubuntu 10.10.
So far so good.
Waiting for my pile of Moates-ware to arrive to test further.
Old Mar 5, 2011 | 08:15 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Linux/Ubuntu TunerPro RT
Have you tried clicking on the ALDL comms without a cable attached to see if it can initialize a port?
Old Mar 5, 2011 | 10:30 AM
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
I did not. Dont know what the 'aldl comms' is.
The button with the cable/plug?
I clicked it, and it said "Hardware not found". Which is correct. I have nothing hooked up to it currently.
Old Mar 5, 2011 | 11:19 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Try connecting to the ALDL and see what it says for the port init. You tried connecting to an emulator by the sounds of it.
Old Mar 5, 2011 | 11:36 PM
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
I think you misundertood. I havent connected anything to the computer yet. Im first testing TP.RT to see if it installs and even opens in Ubuntu. It appears to open and be intact. Now im just waiting on my Moates-ware to arrive to actually hook up to the ecm, and see if TP.RT actually fully functions in Ubuntu.
Old Mar 6, 2011 | 09:36 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
there was a thread in the TP forums about how to use WINE with tunerpro, IIRC, it had no communications issues...
Old Mar 10, 2011 | 12:40 PM
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
I cant get Ubuntu to recognize my burn2. Or intsall the flash and burn software(via wine). But I have xp on my laptop. So no big deal. Just wanted to try it.
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
GTAman
Sep 21, 2015 09:57 AM
tmellott89
Aug 16, 2015 02:58 PM
