TPI 165 : BLM's 108-110 INT 95-132 WB O2S 1.06-1.15 Lambda
Old May 26, 2011 | 08:17 AM
C409's Avatar
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
Cruising datalog shows BLM's mostly flatlined at 108 with INT mostly in the 118-128 range but the Wide Band is reading way lean ... if I lean it out by fuel pressure adjustment the WB goes leaner ... light throttle application drives the WB to 1.25 - 1.45 range .... the NB O2S is heated and new with same readouts as the old ... no exhaust leaks and the plugs look good .... changed wires too thinking mis-fire on the NB side ........
Old May 26, 2011 | 09:04 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: TPI 165 : BLM's 108-110 INT 95-132 WB O2S 1.06-1.15 Lambda
What are the narrow band o2 sensor offsets in the bin? It could be trying to command a much leaner air fuel due to milivolt offsets, but lambda 1.25-1.45 is extremely lean. Is the wideband calibrated properly?
Old May 26, 2011 | 03:55 PM
C409's Avatar
Car: '87 Vette C4
Where to pick up O2S offsets in the bin ? I'm using 32B / Tuner Pro ... Wide Band was re-calibrated on Saturday ...
Old May 26, 2011 | 05:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
there are only a few o2 sensor tables but I dont see it in the 32B xdf file. I use 6E mostly and the expanded 6E xdf. There are some high and low o2 offset tables you can adjust the swing point to target a different air fuel ratio.
Azrael91966669
25
Jun 20, 2017 04:04 AM
CORV3TT3
Aug 23, 2015 11:26 AM
ezobens
Aug 19, 2015 10:29 PM
tmellott89
Aug 16, 2015 02:58 PM
Sanjay
Aug 12, 2015 03:41 PM
