40 PSI Fuel Pressure on TBI?
Old May 28, 2011 | 12:14 PM
nick9004's Avatar
Car: 1981 GMC Jimmy
Engine: 350 TBI
Transmission: TH350 soon to be 700r4
Hey guys, If my math is right looks like I need to run bigger injectors. Having a hard time finding any. I seem to be running out of fuel in the middle to high AE tables. Is there anyone running 40PSI on a TBI setup? Obviously I'll be buying a new pump, regulator, all new lines. My real question is, will the injectors still operate correctly and reliably at that pressure? My engine is a 350+.030. Flat top pistons, Decked, Intake, Headers, Dual Exhaust, RV Cam. Looking for max HP of about 350. Right now I'm using stock TBI Truck injectors. Does it seem reasonable I need that much pressure?
Thanks in advance for any information!
Old May 28, 2011 | 01:06 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: 40 PSI Fuel Pressure on TBI?
I use a little extra pressure. Has worked out well for me.
GM used up to 32psi on the system, I've pushed it to 65.
Being able to custom tune is essential.
Old May 28, 2011 | 03:19 PM
nick9004's Avatar
Car: 1981 GMC Jimmy
Engine: 350 TBI
Thanks for the reply xch3no2. Are you saying you currently run 65psi all the time? or you've tried 65psi in the past? Thats a lot of pressure! No injector failures? I just bought EBL, I've been fighting the 160baud stock computer for tuning with a NB. Lets just say after a year and a half and my aldl cable failed... I was ready to spend the money on EBL... So Ive got the tuning down, Now just starting from scratch with EBL. Im trying to get my fuel supply right first though.
Thanks! If your running 65 I wont worry about 45 haha. What kind of pump and reg. are you using?
Old May 28, 2011 | 03:59 PM
xch3no2's Avatar
Transmission: TH400
Pump,
http://www.diyautotune.com/catalog/s...ump-p-291.html
Regulator.
http://www.summitracing.com/parts/MAA-4305M/
Pressure sender,
http://www.summitracing.com/parts/ATM-2246/
Today's pressure is 54psi. I've been over 50psi for a year, no injector failures.
A smaller fuel pump had me pushing pressure over 60 trying to keep up, it could not & got replaced.
Old Jun 2, 2011 | 01:23 PM
Ronny's Avatar
consider using a VAFPR so as to reduce the fuel at low map area and idle.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
pimp2303
Jul 27, 2017 02:03 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
