$8D/manual trans -- oscillating idle only during deceleration when out of gear
Old Jun 2, 2011 | 11:01 AM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Hi.
I just want to throw a hint out there if anyone else runs into a problem I had...
After several years of chasing my tail with a really annoying 'bug' in the TPI conversion of my Monte Carlo, I finally found the culprit of an oscillating idle that I used to get when I shifted my T-5 into neutral while slowing down. Once I was stopped, the idle would instantly stop oscillating.
The fix was hiding at address 0x81E8 where you'll find either 0xC0 or 0xFF depending on your calibration. Mine was set to 0xFF, changing it to 0xC0 cured the problem.
Code:
; IDLE SA PARAMS
L81E5: FCB 15 ; 15 SEC, IDLE SA INHIB DISABLE RICH TMR THRESH
L81E6: FCB 64 ; 800 RPM, LO GAIN DESIRED RPM THRESH
L81E7: FCB 96 ; 1.2 SEC, LO GAIN XISITION DELAY
L81E8: FCB 192 ; 0.75, LO GAIN UNDER SPD MULT
L81E9: FCB 128 ; 0.5, LO GAIN OVER SPD MULT
L81EA: FCB 8 ; 100 RPM REQUIRED RPM OFFSET
Good luck and happy tuning.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
mizz0313
Aug 12, 2015 06:45 AM
