Bad MAF?
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Bad MAF?
I know some might not agree that this post belongs here, but I put it here because I think I will get the fastest and most accurate response from the tuners, so here goes.
Checking with WinALDL, the MAF sensor is reporting around 7g/s with the engine turned OFF. Is this correct? How can the MAF be seeing airflow when there is none?
Car: check
Engine: check
Transmission: check
Re: Bad MAF?
RBob.
Car: 1985 Z28
BumpaD82
Feb 26, 2016 02:57 PM
MikkoV
Sep 9, 2015 04:25 PM
