e-85 start to finish conversion , might be long
Old Jul 15, 2011 | 06:11 PM
turbotater's Avatar
i will try to document what i am changing using a SAUJP 8D 730 ecm
The car is a 1992 firebird with the following combo
383 cu in - 906 vortec heads with bowl work - 220/230 @.050 cam approx 11:1 compression - 230 cranking compression. 7004r with 3900 stall speed converter. current 3.23 gear ( 9in in process with 4.10 gear ) 28"x9" slick.
I also have a Innovative LC-1 wideband
I am using tunerpro rt for my changes. here goes. i have done this so far
Scalars
Setup , cylinder volume was 713 cc now 784
Setup , injector flow rate was 22 lb hr now 30 lb hr
Knock enable min. vehicle speed was 2 now 10
Low Octane retard amount was 6 now 3
Stoichiometeric A/F Ratio was 14.7 now 9.8
tcc lock hi gear min speed was 38 mph now 48 mph
tcc lock low gear min speed was 38 mph now 45 mph
tcc un lock hi gear min speed was 36 mph now 46 mph
tcc un lock low gear min speed was 36 mph now 43 mph
crank pw vs coolant temp was 200.01 now 146.67
Flags
vats set was checked now unchecked
WB opt 1 b5 innovative WB was unchecked now checked
V4 opt 1 use Z69 ve table was unchecked now checked
Tables
Spark Adv main 90 kpa + 28 degree above 3200 rpm
Spark Adv main extended 90 kpa + 28 degree above 4800 rpm
ve lower table see pic below
ve upper table original , all values 0
ve upper table extended see pic below
Old Jul 15, 2011 | 06:12 PM
turbotater's Avatar
Re: e-85 start to finish conversion , might be long
Old Jul 15, 2011 | 06:14 PM
turbotater's Avatar
am i going in the right direction ?
i am going to load this tomorrow and fill up with e-85.
i used ve tables that kept the a/f around mid 12's on gas
Old Jul 16, 2011 | 09:20 PM
J_D_'s Avatar
My car is entirely different than yours so I cant compare. Ive been running E85 since 12-09 and love it. I have the 165 ecm and MAF and took a totally different approach to the tune. (I have no clue on speed density) Be sure your pump can give you the extra fuel volume needed. I left stoich at 14.7. The ecm doesnt know what fuel you use and the O2 sensor just measures O2. I gave it a lot of extra fuel for those winter starts and gave it some advance to take advantage of the high octane.
Lots of bad info on the net about this too, you need to filter that out.
Old Jul 16, 2011 | 10:26 PM
88gunmetalgta's Avatar
30# injectors are kinda small for a 383, let alone E-85, aren't they?
Old Jul 17, 2011 | 01:50 AM
turbotater's Avatar
when the car was running 108 mph on 22 lb injectors i was seeing duty cycles of 95% - 104%. the other night with 30 lb injectors i was seeing 77 % duty cycle. i am hoping that there is still enough room if not i will bump the fuel pressure up a little.
i didn't get a chance to try today hopefully tomorrow or so
Old Jul 17, 2011 | 09:34 AM
J_D_'s Avatar
I'm running the red Bosch IIIs at 56# FP on my 350. It sees 90% + at WOT. Car runs 12.80 at 108 - 110 depending on the air. Its reading 915mv on the narrow band. I cant remeber what it was on the wideband, its been a while.
Old Jul 17, 2011 | 12:49 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Have you made any hardware changes? (are any suggested?)
I'd like to try the E-85 next year in my 10.8:1, 406 so I'm interested in how this goes for you.
Old Jul 17, 2011 | 06:41 PM
J_D_'s Avatar
The rubber fuel lines under the hood were 23 years old. I replaced them with teflon core braided lines, for safety. There is still original rubber line at the tank. If it leaks, at least it wont be spraying on the headers. Fuel filter is stock, thinking about replacing it. Already had a Walbro 255 pump, no way stock could keep up. I cant think of anything else. Its been about 12000 miles since I switched, so far so good.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
