NVSRAM and vista
Old Aug 3, 2011 | 10:36 AM
Jaysz28@work's Avatar
NVSRAM and vista
Having issues getting the GUI to work in Vista. As in I click 'Upload Bin', nothing happens. Only command that seems to do anything is 'quit'
Following info here https://www.thirdgen.org/forums/diy-...ack-based.html
I found the link was dead, so navigating activestates website, I found this
http://www.activestate.com/activetcl/downloads
and downloaded the Active Tcl 8.4.19.5 (one from original link is 8.4.19.3)
then downloaded the tool that MonteCarSlow posted. It will open, but won't allow me to do anything.
I even followed the suggestion here
https://www.thirdgen.org/forums/diy-...tup-tools.html
and even used firefox as suggested here.....
https://www.thirdgen.org/forums/diy-...m-gui-not.html
Any insight? Perhaps it is some sort of setting within vista itself? I dunno......
I'd really like to be able to use my new(ish) laptop since my XP one is about to give up the ghost.... I can datalog with the new laptop, so something is going right.
thanks
-jason
Old Aug 4, 2011 | 09:43 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: NVSRAM and vista
Hrmm, was hoping someone could chime in here... this is a little over my head.
I managed to get datamaster and tunerpro working, just can't upload any changes until I resolve this issue....
and I've never used Vista before, so I am certain that its the problem.... or a loose connection between the seat and the keyboard lol
Old Aug 4, 2011 | 05:58 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Couple things that may help,
Check that you have the latest release of the RTPtools.
There was an original version that I had a problem getting to work, the second set worked easily. Not sure on the dates, my old one says 2005, the newer one is 2006 but I may have edited it so I'm not sure.
Anyway, try more than one of the tool sets to see if it works.
Maybe there is a way to run the Active Tcl in compatability mode as XP or something. You should be able to get the Wish.exe to open by association to the Active Tcl program.
Edit: Are you running 64 bit? There is a different installer for that.
If you do get it working, I found a neat way to use it within TP5.
Create a Custom tool
Name = NVSRAM Tools
Tool Path = C:\Tcl\Bin\Wish.exe (Substitute your actual path if needed)
Cmd Parameters = C:\ blah \ blah\ RTP4-Tool.Tcl (This file's location)
Create a keyboard shortcut in TP (What ever you like)
Do your edit, save the bin.
Then when you want to upload your bin, disconnect your logging connection and hit your hot key.
The dialog will come up and you can then dump your changed bin.
You can then close the NVSRAM tool and reconnect the logging.
Old Aug 4, 2011 | 06:00 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
I had the same problem when I went to Windows 7.. Apparently you have to have the cable hooked up so that the GUI sees there is a open com port..
Old Aug 4, 2011 | 08:22 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Thanks for the replies
I am running 32 bit as far as I know.
I will check the compatibility mode for wish.exe, I kept trying to use it on the actual rtp4 tool.....
and I will also try connecting the cable to see what happens.
Thanks!
Old Aug 5, 2011 | 04:50 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Ok, got it working
Had to change wish.exe compatibility to XP
and had to plug in/select the com port for the cable
Gentlemen, thank you very much!
Old Aug 5, 2011 | 04:59 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
excellent!
junkcltr
26
Jan 22, 2022 10:53 AM
Ruiner
Mar 28, 2012 09:13 PM
383 stumppuller
Apr 17, 2009 01:12 PM
84KYSS
29
Sep 28, 2008 10:30 PM
Ronny
Jul 25, 2007 04:41 PM
