spark advance table
Old Aug 14, 2011 | 09:04 PM
astoneburner's Avatar
Car: 1989 IROC
Engine: 5.7 TPI 3"Borla exh
Transmission: 700R4 man valve body BM SHIFTER
Axle/Gears: 3.23 posi
spark advance table
Need good spark advance table to start tune on 89 l98 no egr or cat .
running arap now and to much spark advance
Thanks in advance Alan
Old Aug 15, 2011 | 12:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: spark advance table
Head over to Mike's site and grab a stock BIN:
http://www.eecis.udel.edu/~davis/z28
RBob.
Old Aug 15, 2011 | 01:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
^ what he said or start with a AUJL L98 bin. Much less timing for iron head fbody motors. Then take that table, zero out PE spark but add that back into the main table, and smooth it all out. Make max timing around 34 deg for now and bring it all in by 2800 rpm or so and your good to go.
Old Aug 16, 2011 | 02:06 AM
Car: 1989 IROC
Thanks for the info i will give it a try
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Jorlain
Oct 8, 2015 01:57 AM
Jlanz55
Sep 9, 2015 09:09 AM
