V6 Memcal mod to run in V8.
Old Sep 5, 2011 | 11:05 AM
89vette's Avatar
So I have some spare V6 Memcals for 7730 ECM's laying around and I wondered if I could use them. SO I yanked out the factory chip and Soldered in a new AT29C256 and loaded it up with my bin. The car starts and runs fine except I get a Code 41 Cylinder Select Error.
Can I modify this Memcal to work? I just want to modify a memcal to work with my Autoprom. I've done a search where it talks about tying pins together but no detailed descriptions or pictures. I'm not sure which pins these are. It looks like if I am reading it right the pins are numbered 1-66 and go up and down while going across. So the pins to jumper are on the little blue ones under the ESC board?
Old Sep 5, 2011 | 11:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: V6 Memcal mod to run in V8.
Tie MEMCAL pin 56 to ground. This sets the injector firing rate. Yes to the MEMCAL pin numbering. 1-2 across, then next row for 3-4 and so on until you hit the other end of the MEMCAL.
RBob.
Old Sep 5, 2011 | 11:24 AM
89vette's Avatar
Thanks. I just did it and it works great. Thanks for the clarification.
Old May 29, 2012 | 02:21 PM
traktormats's Avatar
RBob.
Is there a picture of this?
From which side you start counting
Old May 29, 2012 | 02:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Jun 10, 2013 | 09:17 PM
Bones232's Avatar
Car: 1991 Camaro RS
Engine: 355 Vortec TBI
Does this mod work for the 7427 v6 memcal also?
Old Jun 10, 2013 | 09:19 PM
Engine: Lb9
Transmission: M20
I think there is a thread on gearhead-efi regarding the port fuel mod and the 427 ecm
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
customblackbird
Aug 15, 2021 10:16 PM
NWAsonoma
Aug 18, 2015 05:45 PM
matthew911
Aug 12, 2015 09:38 AM
