TunerPro data flickering
Car: 91 Z28
Does anyone know why pretty much all my data seems to flicker when I am monitoring? I have the moates aldl usb cable and while I have it scanning every single one of my sensors flicker.
Car: check
Engine: check
Transmission: check
Re: TunerPro data flickering
RBob.
Car: 89 Formula
Engine: 383 SBC/HSR
RBob, you're correct, it's a packet error........there is a fix for it. You basically create a macro command that inserts a pause in the ADX file under "Commands". Or, you may need to increase the amount of time in your existing pause. The information is being processed to fast and Tuner Pro cannot display it correctly, thus causing all the parameters to flicker.
Tomorrow, I'll post where I inserted my pause and how long it was. I don't have my laptop on me and can't remember it off hand.
Car: 91 Z28
Thanks it would be nice to get a readable datalog for a change. I just noticed too that in that log when I started the car it was the first start of the day stone cold and 71C seems abnormally high for a startup coolant temperature. My car starts kind of hard it takes like 2-3 seconds so I'm wondering if that could be my issue. Looks like a new CTS is in order.
Car: 91 Z28
Fixed it. I did a little google searching and found it on the tunerpro forums. I added a 15ms pause and did a test datalog and it works great!
