Tuner Pro
Old Oct 8, 2011 | 03:24 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Tuner Pro
I was wondering if there is a way of adjusting the main spark table in TP5. I know how to add and subtract timing. My issue that my timing light is off 1.5 degress to the value in the same spot in the table. For example I have all timing in by 2800 RPMs 28.83* above 2800 at the same point on the timing light shows about 30.5*, I've verified this with 2 different lights. I'm only using the main spark table for timing, PE mode SA is all set to 0.
Old Oct 8, 2011 | 05:19 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Tuner Pro
It depends more on the code than Tuner Pro on how you would accomplish this.
Make sure your base timing matches your initial timing for starters.
Old Oct 8, 2011 | 05:25 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Tuner Pro
yeah check the base timing in the bin and whats on the timing light with EST disconnected. Make sure they match. Also you sure the balancer timing marks are accurate?
Old Oct 8, 2011 | 06:41 PM
Car: 89 Formula 350
Re: Tuner Pro
yeah, I checked base timing with est disconnected and its set to 8* btdc in the tune and shows that on the light as well..as far as the balancer timing marks, they were all setup by my engine builder
Old Oct 9, 2011 | 09:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Tuner Pro
The other item is the latency settings. This table compensates for the latency of the ICM. And it caries between various modules.
See this link for more information on latency:
https://www.thirdgen.org/forums/diy-...ncy-table.html
RBob.
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
rubyred88
Sep 17, 2015 02:19 PM
85Special
Sep 3, 2015 04:21 PM
