Idle RPM vs Coolant Temp
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I was looking to lower my RPM at idle a little. I was wondering if that's only controlled in Tuner Pro in the tables with "Idle RPM vs Coolant Temp. I have the RPMs all set to 750 at temps over 111* but it seems to only go down to around 850RPMs.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Idle RPM vs Coolant Temp
I think this is only part of how to control idle quality.. I remember setting this a bit lower than what I wanted.. I'd have to verify ... If you have the ability to emulate, try just fooling around with this by putting, say, 650 and see what happens.
Also what is your TPS %? Should be 0.54 volts.You set this by adjusting the screw on the driver's side TPS sensor.
Car: 89 Formula 350
Car: check
Engine: check
Transmission: check
In P/N there is an idle speed adder. This will increase the idle.
There are also the deadband values. This allows for the idle to vary from the desired value. This prevents the IAC from continuously hunting.
RBob.
hydrolic144
Oct 4, 2015 08:23 PM
