vortec 383 TPI spark advance tables?
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Does anyone have a spark advance table I can reference? I'm trying to finish my spark knock issues, and I think I have too much SA; 8 base plus up to 34* which I bet is my spark knock problem. This only happens under light load while driving over 110 deg F though it runs pretty good cold. I've heard vortec heads don't require much SA so I'm kind of curious to know.
Car: check
Engine: check
Transmission: check
Re: vortec 383 TPI spark advance tables?
Recall that the base timing is subtracted out within the ECM. So it doesn't affect the end result. IOW: it isn't added to what is in the SA table.
RBob.
I'm using this $8D timing table on a nearly stock 350 TPI.
http://s239.photobucket.com/albums/f...t=DSCN3384.mp4
dave w
dave w
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
