good base tune tbi
Old Nov 11, 2011 | 09:09 PM
davveek's Avatar
good base tune tbi
just wondering if anyone knows of a good base tune for my 350 tbi? it has a 504/504lift 294/284 dur. 105 lobe sep. cam 11:1 compression 454 tb 65lb injectors. it does not idle at all with the stock tune it runs very lean and i dont want to blow it up. thank you guys.
Old Nov 11, 2011 | 09:10 PM
davveek's Avatar
Re: good base tune tbi
the ecm is 16146299 $99 mask and i am using tunerpro with moates autoprom package emulator chip burner datalogger.
Old Nov 14, 2011 | 12:00 PM
Ronny's Avatar
did you locate a start up .bin on Moates site? that is where to obtain.
You will most likely find nothing that will be close for your application.
you will need to set BPC and pull fuel at areas of overlap occurring. Idle and off idle lower rpms(<2000- map 25-50).
You may end up having to run OL with a WB for reference.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
89-S-dime
Aug 12, 2015 11:57 AM
