Are these the correct files for 730 3.1L auto?
Old Jan 9, 2012 | 07:40 PM
  #151
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Are these the correct files for 730 3.1L auto?
Originally Posted by EagleMark
Everything you learned will transfer easily to $8D. Grab the $8D stuff and open it in TP and take a look.
Im still pondering this idea? I love all the extra parameters in $8D that everyone has. Makes sence to why i look at all the stickys on 730 ecu's and I cant find the stuff there talking about!And if the stuff is in my mask its a different header name.
Im not sure if there is a similar bin that is close to mine(that works with $8D) that i could use and transfer all the info. There is like no info at all on this swap. All i can find is people trading out there $88 mask and such for a $58 or $8E (IIRC those were the masks, wow theres alot of them) mainly swaped for turbo applications......
Old Jan 9, 2012 | 07:49 PM
  #152
RBob's Avatar
Car: check
Engine: check
Transmission: check
You have to use an $8D BIN, such as AUJP ('90 5.7l TPI, auto). And also use a $8D XDF and ADS file.
Then change various calibration parameters. Such as # cylinders (2 places), displacement, injector flow, spark and VE tables. Then flash it to a chip and go from there.
RBob.
Old Jan 10, 2012 | 03:10 PM
  #153
fasteddi's Avatar
Car: 1991 Camaro RS
RBob.
Ok sounds good, thatll keep me busy. No pin out though correct?? I dont change any physical wiring.
Old Jan 10, 2012 | 03:44 PM
  #154
RBob's Avatar
Car: check
Engine: check
Transmission: check
As previously posted the EGR is different, 3-wires versus 1-wire for $8D (digital versus vacuum).
The AIR system is 1 solenoid for the 3.1l engine. The TPI $8D is set up for 2 solenoid AIR system. This is an option flag change in the calibration.
IIRC, there is something with the A/C compressor control too. Can't quite recall what it is. Dash switch polarity maybe?
You should get the wiring for both and compare them. Then do the best you can and see what happens. Correct along the way. BTDT many times. The key is to not expect it to be a plug & play, that discovery/changes along the way may be required.
Also check the P/S switch, in $88 it is used. Odds are that there is an option flag for $8D to use it if required.
The major I/O will be the same as they are dedicated to that function. Items such as the O2 sensor, MAP, TPS, EST & ESC interface (among others) is the same pins. This is due to dedicated hardware for these functions.
RBob.
Old Jan 10, 2012 | 04:52 PM
  #155
fasteddi's Avatar
Car: 1991 Camaro RS
Ok RBob thanks again for the help, i already changed some values, Prom ID, injector flow, VSS, and # of cyl, stuff like that. Ill look up some wireing diagrams and see what they look like.
I dont have AC in the car or the AIR system, but i do have egr so ill do some researching.
Old Jan 10, 2012 | 05:34 PM
  #156
fasteddi's Avatar
Car: 1991 Camaro RS
Ok the i found the pin outs on a 1990 TPI and they look the same, it was actually easier to find the pin outs on a 3.1L but seemed the same as much as i can tell.
Old Jan 10, 2012 | 11:38 PM
  #157
EagleMark's Avatar
There's wiring diagrams with pin outs for V8, 2.8L and TBI for the 1227730 here:
http://www.gearhead-efi.com/Fuel-Inj...CM-information
Old Jan 11, 2012 | 02:06 PM
  #158
fasteddi's Avatar
Car: 1991 Camaro RS
for the info!
Old Jan 11, 2012 | 05:32 PM
  #159
fasteddi's Avatar
Car: 1991 Camaro RS
Ok the more i get into this info im thinking i just need to do this transferr of info once, and im not thinking th $8D can handle boost(+100kpa). Is there a bin and xdf that will work with my 730 ecu with or without doing the pinout? What about $59??
Old Jan 15, 2012 | 10:01 AM
  #160
fasteddi's Avatar
Car: 1991 Camaro RS
Ok ive got the $59 bin adx and such. Now the Bin i have is off of the code59 site. There are many bins on there but can anyone point me in the right direction for a bin that will work better out of the box?? Im gonna need to datalogg alot to get the tune down for the bin and im not sure which original Bin to get for my application.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
89fast5oh
Sep 27, 2015 09:04 PM
sunbound
Sep 5, 2015 11:52 AM
355tpipickup
Aug 19, 2015 10:02 PM
