LS1 programming thread
Old Jan 2, 2012 | 08:44 AM
J_D_'s Avatar
Probably a dumb idea.
The LS1 programming thread got me thinking. (Dangerous) Why not use a cable TB an HEI and run it with an EBL ?
Distributor drive, below.
http://www.ebay.com/itm/GM-Performan...r#ht_500wt_969
Old Jan 2, 2012 | 09:13 AM
EagleMark's Avatar
Re: LS1 programming thread
Although that is a very cool part! Doing away with DIS ignition is a step backwards...
Old Jan 2, 2012 | 09:36 AM
J_D_'s Avatar
I like the LS1 ignition also. When I saw the other thread I was thinking about an easy way for guys doing conversions to do their own tuning. I "think" this could be done.
Old Jan 2, 2012 | 08:33 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
It can be done if you want to just run it like an L98. It will get the LS1 in there, but you'll still have the older HEI ignition and batch fire. The newer ignitions are a huge step up from the old HEI systems. If the car has a 4L60-E, it can be run with a TBI PCM. Probably good if you have an LS1 for a swap, but an existing LS1 car its a step backwards (or two).
Old Jan 2, 2012 | 09:36 PM
J_D_'s Avatar
I realize its a low tech answer. Just thinking about a buddy, putting a modded LS motor in a Vega. It would be an easy way to get it going. He has a 200 R4 to go behind it. Only needs lock up. Thanks for the input.
Old Jan 3, 2012 | 01:57 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
instead of using a distributor, have you thought about the MSD LS box?
from my understanding you can tune the spark map with a laptop or use chips for the timing.
i would guess you could use the tach output from the MDS box to the EBL and disable the spark control in the EBL.
Old Jan 3, 2012 | 10:52 AM
Ronny's Avatar
I am aware the guys that retrofit an LS with carb use a HEI distributor. Would that require a cam swap for dist gear or maybe not as it feeds the oil pump?
Old Jan 3, 2012 | 01:03 PM
J_D_'s Avatar
Its part of the kit. The gear that drives the dist. bolts to the front of the cam.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Linson
Sep 21, 2015 01:08 PM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 10, 2015 07:55 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
