Smoothing
Old Jan 15, 2012 | 07:51 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Smoothing
I have been tuning for about the last 12 years thanks to RBob, Grumpy, this board, and some other great people like Craig and Mangus. Spent quite a bit of time on TBI w Xfire first using 7747 then onto EBL. I'm now doing
LT-5 motors which is still SD so lots of commonality w TBI.
One thing I have never really used is the smoothing available in either EBL or TPRT. Most of the smoothing I have done is manually.
Anyone use smoothing features regularly? If so, do you have a process you use,
what factors, and how are your results?
Old Jan 15, 2012 | 08:18 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: Smoothing
I would like to know also
Old Jan 16, 2012 | 12:18 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: Smoothing
I'm not in the habit of smoothing, other than by calculation/hand.
Old Jan 16, 2012 | 04:16 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Smoothing
i don't use it a lot, but i do use it occasionally, mainly when i've messed with a lot of the table im working on like when starting with a fresh map.
i normally set it for very little change, 0.9 or 0.8 with Absolute checked.
its quick and saves time when you've made a lot of changes. once i've gotten the map pretty close to what the motor wants, i don't use it.
you may be able to use it to quickly make changes to most of the map by just picking a few spots in different areas on the map and setting them above or below what you think they should be and highlighting the whole map and then smooth it. i've never tried it that way so i have no ideal if it would be worth it or not.
Old Jan 16, 2012 | 07:35 AM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Re: Smoothing
Denn,
I'll need to look at that. Whenever I have used it it's been with a small factor
(ie .9 or .95) after I have done the majority of the map changes.
I really just want to clean up some of the rough spots that I didn't get to w a scan. I have found that even w manual smoothing, the feel of the motor really becomes more consistent and less "choppy" and "jerky" if I can describe it properly. I wonder if it helps in terms of emissions or fuel economy.
Old Jan 16, 2012 | 09:10 AM
EagleMark's Avatar
Re: Smoothing
http://forum.tunerpro.net/viewtopic....ight=smoothing
Old Jan 24, 2012 | 06:11 AM
Cuervo's Avatar
Car: 91 Suburban 3/4 4x4
Engine: GMPP HT383
Transmission: 4L80E
Axle/Gears: 14BFF 4:56 Detroit Locker
Re: Smoothing
Wow, after reading that post, it seems the author wrote it to work by highlighting just one cell at a time.
Old Jan 24, 2012 | 07:25 AM
EagleMark's Avatar
Re: Smoothing
Exactly!
Old Jan 25, 2012 | 07:57 PM
Cdeez's Avatar
Car: Too many to list...
Re: Smoothing
Originally Posted by EagleMark
Exactly!
Thanks for posting that link above EagleMark....
I have been under the assumption all this time that the smoothing was inteded to be used on multiple cells......
Old Jan 25, 2012 | 08:52 PM
DENN_SHAH's Avatar
Re: Smoothing
when i use it, its always been on the areas i was working on plus 1 or 2 more rows/columns that i didn't touch.
Dominic, i don't know if it would really help with emissions or not.
i never tried it when i tuned my car to pass emissions. i ran it thru the dyno test and made a data log and then worked the areas it was at during the test.
for fuel economy, i use hiway mode.
i would guess if you had much of a spike up or down it could cause hiway to turn off sooner than it should.
it does help with driveability, without spikes in the maps it helps the motor run much smoother. even pretty small spikes at lower loads/RPM can be noticeable.
db057
Jan 10, 2020 08:55 PM
FormulasOnly
Jul 23, 2018 08:47 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
mfp189
Sep 27, 2015 09:25 AM
