PRP Gain Multiplier
Old Mar 2, 2012 | 01:11 PM
Ronny's Avatar
PRP Gain Multiplier
RBob Quote: Reducing the gain and multiplier values can reduce
this problem(larger than stock cam). The values in these tables can sometimes be cut in half.
Is the above the one RBob refers to?
My values are about 2.5X that of stock LO3 .bin
I am 350cid 25 lbs FP with 75 lbs inj's(2560)
should I have decreased vs increase? If so how much?
TY.
Old Mar 2, 2012 | 01:20 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Re: PRP Gain Multiplier
Ronny,
Check my PM on this. Let me see if I can dig up my final EBL bin and post for comparison.
Old Mar 2, 2012 | 01:22 PM
Ronny's Avatar
02 error bias
RBob quote: IDLE Also, do not forget about the O2 error bias value at: 0x2F7. This value can be used to decrease the AFR at idle. Again, for a rumpity
engine, it can calm down the idle.
Idle O2 Error Correction. Is that it? I have set to 75%
If so how much should I reduce? See prior post.
Old Mar 2, 2012 | 01:35 PM
Ronny's Avatar
Re: 02 error bias
Thanks Dom
Old Mar 2, 2012 | 01:44 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Here's the O2 Terms I was using. BTW, I am using EBL v 19 .xdf which is what I have. I know there have been many enhancements since then.
Old Mar 2, 2012 | 02:01 PM
Ronny's Avatar
error disregard
InfernalVortex
Apr 20, 2021 11:31 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
