Oxygen sensor all over the place!
Car: 87 Iroc
Engine: 5.7L TPI
Transmission: Built 700R4
Axle/Gears: 3.23 posi
hey everyone, i am trying to tune my 87 350 tpi for better mileage. i am working with the ARAP bin and adjusting stuff as needed. so far i have brought back the timing tables to something reasonable, and long crank fix. i am working right now on getting my BLM's right about 128 +/- about 4. I have most of the range within 2 right now and am readjusting for a new oxygen sensor. my problem is this new oxygen sensor reads everywhere. at idle, it will be just jumping from 0.150 to 0.750, it never stays at any given rough value for more than maybe a second or two. i have gotten my BLM's at idle to be 128 fairly consistently, but the oxygen is going crazy. is this normal or did i get a bad sensor? thanks for any input.
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: Oxygen sensor all over the place!
That sounds like the normal swing of an NBo2, it is called a cross-count.
Crosscounts are instigated and controlled by proportional gains and o2 volt limits.
Car: 87 Iroc
Engine: 5.7L TPI
how come it is so drastic though? i understand that it is leaning out or richening but that seems like a big swing
Car: 87 Iroc
Engine: 5.7L TPI
so its a perfectly good o2? the one that came out was alot smoother, granted it could have just been toast as it was most likely the original O2. thanks guys for your help!
FormulasOnly
Sep 10, 2015 09:07 PM
[Sold] T5 electric speed sensor
Eric-86sc
Sep 7, 2015 02:10 PM
